The quench (old texts call it "squench") band is pretty important on these I6 engines, even more so with crummy gas (aka low octane numbers). It controls the burning flamefront by pushing the unburned charge into the burning fireball, reducing the progress of the flamefront toward the cylinder walls. This effect reduces knock and smooths the power pulse.
If the quench band's height is too much, no effective charge movement occurs. If it's too thin (on decked blocks) then the RPM will be limited before 'rod stretch' at high RPM causes contact between piston crown and head. However, before the RPM limit is reached, the performance will be better.
Ford carried the quench band technology to it's extreme in the mid-1960s "FCP" series of FE engines. These 410/428 CID engines had wide, thin (.006") quench bands and deeply-dished piston crowns to contain the flamefront almost completely while it burned. The resulting increase in low-end torque and efficiency ushered in the era of 2.5:1 ratio differentials in Lincolns and Mercurys of that time, getting up to 20 MPG out of the 410 and 428 engines at highway speeds. These engines were RPM-limited to 4000 max, though, with a tricky reverse-advance distributor mechanism that sharply reversed the spark lead above 4k. Hot-rodders who changed distributors to get around this limitation paid a high price in crankshaft damage.
Most hi-RPM motorcycle engines use quench technology to reduce the "droop" in power between the low-end torque peak and the high-end HP peak, which is considerable in small-bore, hi-strung engines. The most common arrangement is the flat-topped piston with the much smaller diameter, semi-hemi head chamber, often with 2 spark plugs. Opening up the quench distance in these engines causes them to fall 'flat on their face' in the all-important midrange power area.
Which brings us to the FoMoCo 200 family. With log intakes, these engines are low-to-mid RPM power curve types, due to the intake system. Because of this, the quench band is very important for improving gas mileage and torque above 1800 RPM (aka HP). This translates to a peppier response at highway speeds, which we all would like..
