What revs will a four speed manual do @ 100 with 3.23 diff
I have had this formula in head since I worked at crane:
MPH x GEAR Ratio x 336 dividied by overall tire hieght (inches) = RPM
100 x 3.23 x 336 dividied by oal in inches 26? = 4174
Remember autos without a lockup converter the rpm will be slightly higher.
manuals are very close
Thats a good formula because its simple, and it works.
Only one thing for nerds like me. There is 2.2% tyre crush on most radials when the car is loaded.
I have a more complicated one which works better but is a PITA to remember.
225/50X 14 is 2*(225*0.50)+(14*25.4) = 580.6 mm (static, unloaded)
Then divide by 5.42, and again by 3.23:1, which gives km/h per 1000 rpm of the loaded wheel on the road. Tyre squash is about 2.2% on a car like yours.
Thats 33.15 km/h at 1000 rpm
Then take 100 km/h, and divide by 33.15, and presto, 3016 rpm.
At 100 mph, or 160.934 km/h, it will do 4854 rpm.
Every one loves to get Falcons nice and low, and 225/5014's do that. Only problem is the tyre is supposed to be 642 mm tall unloaded, so its doing lots more revs each mile.
With a set of 26" (unloaded) tyres at 100 mph, I get 4268 rpm, and 4174 rpm like 80broncoman if there was no tyre crush due to the weight of the vehicle.
4174rpm @ 100MPH which is 160kph
So 4174 minus 40% less (1669) is 2505rpm...............hmm that cant be right becuase thats lower than with the 2.77 gears now!
Isnt the actually tire size in my car 22.86 inches?
112.50mm from > 225*50mm
to inches 112.50/25.40= 4.430 inches
14ich rim 4.430 * 2 (top and bottom?)
=22.86 inches (havent included tire crush)
EDIT*LOOKS like it will be about 2860rpm@100kph*
There is no such thing as KPH. Km/h is correct term, not that I give a hoot.
Well I give a hoot and K is the abbreviation for Kelvin, as in degrees Kelvin.
The abbreviation for Kilo is "k"
So, there is no such thing as KPH and Km/h (Kelvin meters per hour) doesn't make sense.
Kilometers per hour is abbreviated to km/h
</rant>
:oops: :oops: :oops:
I am prepared to say you are right. I am wrong.
(That is only because it is rude to start the first letter of a scentance(sp?) with a little letter.
hello.my name is dean.km/h are something i hate. :wink: )
