Where To Get 1 bbl To 2 bbl Adapter
After having tinkered with the "new" 1100 on my 68 Mustang, I've decided to go ahead and install the 2100 from my 69 302. Where do I find the 1 to 2 adapter? Summit has two but they're for Holley 2300's. :?: :oops:
Thanks.
8) you can use the summit adaptors since the 2100 autolite and the 2300 holley use the same bolt pattern. i have the summit adaptor on my 66 falcon using the 2100 autolite. i have mine facing as it would be on a V8. to do this however i had to swap the bellcrank to the V8 one rather than the 6 cylinder one. i also had to clearance the adaptor to allow for full throttle operation, and i had to bend the lower return spring eye to clear the valve cover. when you bolt your carb and adaptor in place you will likely find the same interference problems i had, minor though they are.
Rbohm,
Do you happen to have a photo of your setup?I've been going back and forth between upgrading to a bigger 1 barrel or going to a two barrel.I'd like to see how it looks.Thanks
I went from this:
To this:
