where to get carb rebuild parts
az1966
Got the engine in to get a rebuild that went ok,,put it back into car,,,, car runs great,,, One problem,, the carb,,, 7 turns or so to get it to run "normal" timing ok,,, took it to the shop to have the "Pro's" take a look. what they say is I've got a vacum leak,,in the carb,,,, not the gaskets, little silver "dutch" caps that cover the power valve and such or the body,, they say it's mostly likely the ( I don't remember the name of the part) "bushings" ? around the throttle shaft or choke shaft. Question is where can you get these puppy's,, regular rebuild kits don't tend to give you the "little" things that you might need. I disconnected the vacuum line from the back fire valve and pluged the carb inlet. no change
200ci 6 popper
manual tranny
1st Gen smog system
No AC
Pertronix ignition
Motor craft modell 1100 1bbl carb
timing set to +6 bftd
thanks for any help/info
