Which starters can I use?
Ford starters are specific to automatic or manual transmission, although you can swap nose cones if necessary if you can't find the style you need. Three bolt starters like the one you have do interchange with the 360/390/428 FE engines, it's the 2 bolt starter that interchanges with the SBF. Your engine is high mount BTW.
Also, make sure the starter you get is clockable or can be indexed. Best bet I have found is Powermaster. You might try ebay also.
Yes, the whole thing moves on a mounting plate. If you get one that can not be indexed the solenoid might hit the block.
