grocery getter
jamyers":24q1og9j said:I disagree. On a cold engine with unseated rings, as long as you have compression I wouldn't worry. (Heck, I've seen an engine run with barely over 40 psi average.) And you don't want them all to be equal, it's an indication of a leak. Get it running, get the rings seated, then check the compression when warmed up. Anything before that isn't going to tell you very much. IMHO.grocery getter":24q1og9j said:that's a lot of compression loss for rings not being broke in, on a bored and properly honed engine.
think about it, they're not equal....
something else is not quite right......
Again, there's likely more than one problem here.![]()
What i'm trying to get across is with these static compression numbers you'd see alot of blowby. on the 65 psi cylinder you'd be looking at 50% of the A/F going to the crankase.
I get the weak numbers on break in, but these are a little extreme.
like most of the posts so far I agree timing is an issue. i'll stand by my thoughts that 65 psi on a new bored and honed cylinder is very weak
(and there's more than one problem).
Three things We can't dispute....Air/fuel,compression and ignition
