well... I havent posted on here for ages... but the old XD is still kickin along without any problems
over summer I swapped the 4speed for a 5 speed T-5 (4speed was getting pretty tired...!), thought id post the pics up here for something to do early saturday morning
box in new home
had to change the uni on the gearbox end of the tailshaft
needed more floor clearance... washers + new bolts did the trick
couldnt find a crossmember that fit on the day, so made up a simple adapter.... bit of steel with 4 holes in it.
anyway... with the new gearbox, it goes a bit harder in 1-2-3 (shorter ratio's) and cruises nicely at ~ 2100 rpm in 5th at 105 ish
fuel economy is also a little better... but cheap as on gas anyway...
since the box is lower... the x-member is closer to the exhaust, it rattles a little bit but only on reverse, so no problem there!
I almost got into trouble with it however, with the 4spd the speed would read about 10 km over... with the new box its reading spot on
I managed to get off for 115 in a 100 zone
comments?
(sorry if the pics pissed anyone on modem off!)
box in new home
comments?
