The way I was taught to measure deck clearence.
Zero the indicator on the deck.
Put the indicator on the piston at A
Rock the piston side to side.
Half way between the high and low measurement is the deck height.
If you put the indicator at B, it should match your measurment.
The theory is, the piston expands and becomes stable at temp. (less rock)
IF THE DECK IS SQUARE!
Some pistons have the clearence measured at D and some at C. A forged piston with .005 measured at D will rock way more than a hyper piston that has .0005 to .001 at E. Obviously a piston with a 4.5" dia will rock more than one with 3.6".
Yet with these differences, ZERO is still the target number.
That is where I started hunting a better method. The deck may not be perfectly square. The difference in cast/hyper/forged/high silicone/low silicone/amount of taper, amount of expansion. Too many variables for zero deck to be the magic number. This doesn't account for aluminum block with steel rods where the deck clearence actualy grows when the block heats up.
If you start recording the closest measurement and compare your notes, you will see some amazingly close numbers. In a perfect world, all of the blocks would have a perfectly square deck, the crank would have exactly the same stroke on all throws, all of the rods would be perfect center to center. This is rare, even with todays tech.
So, in the end, you should measure closely and work off of the tightest measurement.
Zero deck will net you whatever the compressed thicknes of the gasket is.
If you have a steel shim gasket, don't go to zero. It will probably crash.
.035 to .040 total deck clearence is a good place to start.
I post this sumary to make sure I don't lead someone down a path that will lead to heartbreak. If you chose to hunt the ragged edge, do so cautiously. You wouldn't want to find a dead end with a piston traveling at speed.
XPC66
If you take a piston with rings installed and push the ring all the way into the groove, you will see that the ring will not stop the piston from rocking and actualy touching. It will offer some dampening like a shock absorber. I thank you for this insight. This is something I had never considered. I would suspect that it would be pretty effective at dampening on the power stroke under pressure. 8)
