Gentleman, i need help. Is there a dowel pin that goes at the front of the cylinder block on the deck surface to align with a hole in the cylinder head for alignment. Since i had my block decked, i believe the machine shop failed to put the dowel back in the block. Any help would be appreciated.
Second, where can you purchase the spacer ring which goes between the camshaft & the timing gear just in back of the camshaft dowel pin & then the camshaft thrust place gets bolted to the block? Thanks William : :idea:
