i read through a bunch of posts on the Autolite 2100 carb, and think i've got an idea of where to start. but, before i rip the thing apart, i thought i'd share my start-up experience with y'all.
i spent the last month of free nights porting, polishing, cc'ing the new E0 head, not including the week i waited for the maching shop to fix the valve seats i dinged with the grinder (*sigh*). it got a 3-angle valve job with all new parts and a 2-bbl adapter. i just got it running yesterday, it fired right up, and it idles well, but on the road it 'surges' at light-medium throttle just driving at 2000-2500 rpm and just feels sluggish up to 2,500 rpm. it responds pretty well to larger throttle openings, and i did punch it WOT from start (once i was comfortable it wasn't going to fly apart) - it took right off toward 4,000 rpm, then stalled big time. so, the good news is i think there's bunch more horsepower there once i get it sorted out.
here's what i know for sure:
I set a new TDC mark with a dial indicator while i head the head off, and i set the initial advance at 12 degrees. the recurved DSII from reincarnation auto adds another 12 degrees at 2,000, 18 degrees at 2,500 and pegs at 29.5 degrees at 2,950 rpms. i don't have the vacuum advance hooked up at all, but it would add 20 degrees at 14 inHg if i did.
the autolite 2100 came with 49F jets, and has some idle circuitry work done to it by some guy who says he knows what he's doing (k. praxl).
vacuum at idle is about 19 inHg. at the light throttle when it surges it's running in the 12-18 inHg range. any heavy-footedness brings it right down to 5 inHg or less.
fuel pressure after the filter is about 3.5 psig, and it drops a little when i goose it sitting in the driveway, no gage in the interior to watch it when it's on the road. idle screws ended up at 1-3/4 turns out, that was high vacuum at 700 rpm or so.
compression is 144 to 148 in five cylinders, 155 in No. 4. odd, i checked 'em twice.
other mods as listed below, it's the stock cam with 1.65 yella terra roller rockers, autolite 46 plugs/indexed/0.045", headers, duals, t5, etc.
so, two things i'm wondering about are low fuel pressure and lean main jets. the low fuel pressure comes to mind when i punched it and it took off for about three seconds then just stalled at 4,000 rpm. as for the jets, it actually feels like it's running rich, but i see other posts where guys are going to 60's on the jets to get the motors to run right.
thanks in advance for any other thoughts....
