Frankenstang":36obpe5z said:I'm not aware of another port, but why not just plumb a 'y' or a 't' out of the stock location using brass/bronze connections. I believe the bent8's use an extension from a similar location, but you should be able to rig up a splitter setup from plumbing parts and teflon up the junctions. As long as water at back of the head can reach both (dual) sensors (assuming that is what you're shooting for) you should be good.
rbohm":8w1xob4h said:Frankenstang":8w1xob4h said:I'm not aware of another port, but why not just plumb a 'y' or a 't' out of the stock location using brass/bronze connections. I believe the bent8's use an extension from a similar location, but you should be able to rig up a splitter setup from plumbing parts and teflon up the junctions. As long as water at back of the head can reach both (dual) sensors (assuming that is what you're shooting for) you should be good.
8) you can use a T or Y fitting with an oil pressure gauge, but not with a temperature gauge. the thermocouple in the sending unit needs the coolant flowing across it, and if you use a T or Y fitting you get a stagnat pool of coolant around the sending unit and then you get false information that could cost you your engine.
Once you bleed the air out of the coolant system including the upper radiator hose, there will always be coolant on both sides of the thermostat. The only places in a cooling system that there is a chance that you will not have water at all times would be the higest locations on the system. I.E. The top bend of the upper radiator hose or the top resevoir of the radiator, if you are using a closed system type cooling system with an expansion tank both of these areas should be full as well, it's just the old school systems that had a tendacy to need the expansion space.Frankenstang":6dbv0ind said:My concern with putting one in the thermostat housing is that it will not always be surrounded by water unless you're not running a thermostat. When the thermostat is closed a sensor mounted in the thermostat housing will be on the radiator side of the thermostat, not necessarily surrounded by water and not giving as accurate temperature.
Frankenstang":3klim0qt said:Well, just to be clear, my contention was simply that if you put a 2" nipple on the head to a 't' where both sensors are connected, there is no way you're going to get a temperature measure with variance of more than a couple degreees at the sensors relative to in the head. Water is an efficient conductor of heat, it would not be possible for the temperature of the water at the back of the head to be 205* while the water in the 't' (and the sensors' were reading 190). Thermal conductivity just does not work like that. Sure the water would not be circulated in the 't' as well as it would be in a free flowing passage, but it will still ciruculate, and more importantly it will directly reflect the temperature of the adjacent water.
