Fuel pump block-off - does anyone make...
thesameguy
Post #1 by thesameguy » Mon Jun 25, 2012 1:26 pm
I am looking for a fuel pump cover for a '68 200 (which has a different shape than a '72 170, I can say) but it needs to be steel. I need to weld another piece of steel to it, or possibly weld some studs on. Or something. Anyway, I need a steel block off plate. :) All the ones I've found are aluminum.
XFlow_Fairlane
Re: Fuel pump block-off - does anyone make...
Post #2 by XFlow_Fairlane » Mon Jun 25, 2012 2:45 pm
look for a EFI 2.3L ford OHC motor in a ranger or fox. I know the earlier ones had them.
if you are making a mounting bracket from it why not just cut some plate and drill two holes?
Rule: Torque = Fun , Turbo's make Torque
Post #3 by xctasy » Mon Jun 25, 2012 3:17 pm
Same as 1982-1987 EFI Falcon X-flow. Grab some steel plate, and cut to shape with 5/32 drill, then file, then weld you nice fuel pump hanger to it, and your dough is bread
thesameguy
Post #4 by thesameguy » Mon Jun 25, 2012 5:14 pm
XFlow_Fairlane wrote:if you are making a mounting bracket from it why not just cut some plate and drill two holes?
I completely would, if I had the materials & tools to do it. ;) I was hoping for something ready-made that I could use as a base. ;)
xctasy wrote:Grab some steel plate, and cut to shape with 5/32 drill, then file, then weld you nice fuel pump hanger to it, and your dough is bread
Actually, I am not hanging a pump from it. I want(ed) to mount a Ford EDIS coil pack there. After thinking about it, though, I'm not sure that it's a good spot. I'm worried that the weight from the coil pack and its bracket hanging "over" a gasket would result in the gasket failing in time.
I'm thinking now it would be better to use the spots where the factory coil bracket goes. Not sure yet. The fuel pump "flange" is such a great spot from a height/protrusion aspect! The factory bracket from an OHV 3.0l V6 fits about perfectly there! Bah. I'm also not sure if I should care to make this reproduce-able... maybe some other folks would be interested in converting to EDIS as I am, maybe they aren't!
Post #5 by bubba22349 » Mon Jun 25, 2012 6:11 pm
:hmmm: I don't think you would need to worry about a gasket failing from the weight of the coil pack. Think about the force of the fuel pump operating up and down on the cam lobe continuously pushing against the gasket, I think it would be much less with the coil pack.
thesameguy
Post #6 by thesameguy » Mon Jun 25, 2012 6:45 pm
I really have no idea. :?:
The coil pack probably weighs 2-3 pounds, and would be hanging off to the side & have a fair amount of leverage. It really may not be a big deal at all, though. A friend of a friend is willing to cut & weld some metal for me, so I am going to go home & play with some cardboard. :D I wish there was somewhere else on the block to attach things to, but it seems they weren't bolting a lot of stuff to motors back in the '60s. ;) These days there's always a bung or something to bolt something new onto!
Post #7 by xctasy » Mon Jun 25, 2012 7:59 pm
Stock EFI Ford Falcon plate, beside a blown rod and cam Image
wsa111
FSP Moderator
Post #8 by wsa111 » Mon Jun 25, 2012 8:14 pm
Check out the block off plate for a big block chevy. If i'm not mistaken it will fit.
You can get it in chrome plate or just plain steel finish. Bill
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6425CL & MSD-Blaster 8252 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
XFlow_Fairlane
Post #9 by XFlow_Fairlane » Mon Jun 25, 2012 9:38 pm
the BBC plate will kinda work...they are drilled for a 3/8" bolt instead of a 5/16" though
why not mount the coils to the shock tower?
what are your plans for firing them? using the FULL EDIS system??
I am currently going with a 36-1 wheel and GM truck coils and a ford cam sensor with my megasquirt setup.
all you need to make the mount is some steel and a hacksaw. you would be suprised how little it takes to support just that coil.
That gasket will hold up fine (most block off plates are at least 1/4" thick)
thesameguy
Post #10 by thesameguy » Tue Jun 26, 2012 2:17 pm
I am using Megajolt to control the coil pack - there is a thread over in the electrical section:
viewtopic.php?f=7&t=67718
I don't want to mount the coil pack to the body since that would require substantially longer plug wires and leave them hanging in the breeze. Would be a helluva lot easier, though. ;)
kukm66
Post #11 by kukm66 » Wed Jun 27, 2012 10:15 pm
I believe the 289 plates are the same if memory serves me well.
I don't know if these are steel or not.
All Mustang suppliers carry these.
http://www.google.com/search?q=289+fuel ... shop&tbo=u
1964 Falcon Futura Convertible
1964 Ranchero
super4ord
Post #12 by super4ord » Thu Jun 28, 2012 7:22 am
I've used SBF plates on all of mine.
1978 Zephyr Reverse Trike 250 Inline 6/C4...Slowly Progressing Project
1980 Mustang Coupe 200 Inline 6/T-5 manual trans...Upgrading Hotrod Project
2007 Chevrolet HHR Panel Wagon Ecotec 2.2L 4 cyl auto...Daily Driver
2013 Dodge Grand Caravan SXT 3.6L Bent6...Wife's Daily Driver
Explorer
Post #13 by Explorer » Fri Jun 29, 2012 10:30 am
How about using a standard block off plate and mounting coil pack to the two holes reserved for the PS pump bracket(if not using it)? Right above distributor and close to plug wires. Of course I may be looking at this entirely wrong.
66 Bronco half cab, 203 ci, 9.7:1 comp, CI aluminum head and intake, DSII ignition, Clifford header, Keith Black pistons, Isky 256/256 cam, lifters, chrome moly rings, push rods, Holley 390cfm 4v, 4:11 gears, 3-speed, 30/9.50/15's 18.28mpg pushing a 4000lb brick.
66 Mustang Coupe, 200I6 automatic
thesameguy
Post #14 by thesameguy » Fri Jun 29, 2012 4:50 pm
I would love to mount there, but I think I am going to end up using a cam synchronizer from a later car so keep driving the oil pump, so that spot will be occupied.
I think I have a solution - it's posted over in the EDIS thread on the Electronics board.
Users browsing this forum: No registered users and 71 guests
