I'll use metrics in mm's. Hope my English and descriptions are good enough to convey the answers.
Ford America
most likely axed the proposed 1969 introduction of the 2V version of the 250 because of the hood clearance issue. The Australian 1971 M code 170 hp 250 2V had a trick ultrathin 39 mm tall air cleaner and a Stromberg WW 2bbl carb, which is a short deck a Rochester 2CG like carb which was very short but still flowed 300 cfm.
This setup worked really well in the 1971 to 1976 250 Falcons, but it was combined with the direct mount 250 2V cylinder head. The US 250 has a deck height of 9.469" (240,51 mm)tall , the Aussie 250 its 9.38" (238,25 mm), but either way, its either 1.577 to 1.666 inches taller than the garden variety 200 3.3 engine. 40,06 to 42,31 mm's is a lot of thickness to recover.
However, the Rochester 2CG is a little less tall, and if you cut the air horn off a 2300 series #7448 350c fm or #4412 500 cfm Holley 2-bbl, you can loose 35 to 46mm, and bring the total height down to less than 90 mm if you can drop the carb practically on to the stock tin rocker cover.
Look at powerbands 250 engine Tripower with 350 cfm 2-bbl is in a Comete, basically an early round body Falcon...the engine its very tall, yet he still gets hood clearance. On the lower hood late 60's Fords, and the only way to get hood clearance on a Mustang is to trim the carb air horn.
With any Holley 2-bbl air horn removal gives you back 35 to 46mm, and as I've said, it allows you to bring the total height from the rocker cover to the top of carb down to less than 90 mm if you can drop the carb practically on to the stock tin rocker cover.
On all carbs except the Rochester 2CG, the 1 and 2-bbl Holley/Autolite choke air horn is the problem, and there is never more than about 4.5 inches from the hood to the rocker cover.
Its impossible to make a down draft Holley 2-bbl with a functioning choke for cold weather to fit under the hood of a 1969 on X body Mustang, Falcon, Maverick or Granada unless you direct mount.
That's why the Classic Inlines head is so good, it solves the problem.
So does the 1957 to 1962 223/262 passenger car Holley 1904/Autolite 1101/1100 air cleaner
viewtopic.php?f=1&t=69655&p=533863#p533863
CoupeBoy":2mrrhulc said:
Found another one you might want to look for..
Ford Cars with 223's used a low profile air cleaner that held the air filter off to the side (vertical, not horizontal)
But for us Log head types, the solution on a log head is actually very easy to do, although its taken me 10 years to nut it out. It uses one of my 6PT (Six Port Twinductor) intake manifolds, a follow on from my triple carb 6V intake developments. It uses two Rochester 2CG carbs or two Holley 350 or 500 cfm carbs. Discussion about it started when powerband asked some questions about making a 4-bbl version of the Tripower intakes last year.
viewtopic.php?f=1&t=68410&p=524489#p524489
In that, powerband covered off most of the issues, and I then started rolling out a 4-bbl carb to 3 bbl Tripower adaptor.
If the Holley 2-bbl is used, one has the air horn cut off like the second barrel of a 4150/4160/4180C 600 cfm carb. The secondary sits high with its air horn cut off, and the other sits lower operating as the primary carb. The stock 1.5 or 1.75" hole head is used, and four 29 mm holes are cut into the log head to feed the secondary carb. Primary runs like Powerbands 2-bbl center carb. The secondary 2-BBL runs like a Tripower Edelbrock or Offenhauser, where the two outer Holley 1904/1908/1940/Autolite 1100/1101 or Weber 34ICT/ICH kick in on 2/3rds throttle.
PM me if you want to be the first to use it.
