It seams like you guys have all the links.
This is, in my opinion, the best money has to buy.
http://mmb.maverick.to/gallery/files/1/ ... /after.jpg
It follows the French Renualt/Citroen/Peugoet or Toyota Lancruiser or Hilux SR5 way of remote filter location with a simple 2-bbl Weber style carb. Its been done that way since the 1955 ID 19 'Goddese' engine.
Toyota were still doing it in the export carb SR5's with 2.366 liter four cylinder engines in the 90's and Naughtees.
Classic Inlines sells the kit because a little 450 hp 250 Turbo engine makes a car do sub 11 second quarter miles with one of these kind of remote offset air cleaner adaptors,
I guess need to provide re submit the evidence and let the details sink in. Maybee the language I'm using isn't helpfull, but the evidence speaks for itself.
MEL Mercury Edsel Lincoln 223 i6 side air cleaner,
Early Bronco, F100, F150 offset air cleaner on 170 cid or 250 cid its all the same,
A smart Ford standard part offset air cleaner after a fashion. Each solution doesn't ever help reduce total carb height or hood distance because they don't use the good old Aussie 250 2v Ford logic of shifting the carb to the right hand side of the engine bay, or the Mopar 340 and 440 Six Pack Tripower 2-bbl 2300 and 4-bbl Holley 4150/4160/4180c method of savagely cutting down reducing the height of the secondary parts of the carb package.
I trust that everyone here can see in between the lines of the many incarnations of 223 Edsel, 170 Bronco and 250 with F100/F150 air cleaner, and the many alterantive 2V 250 and Classic Inlines head packages. The two are left and right bows to the soulution. I've invented nothing, but the under hood carb space and air cleaner solution is a fresh variation of two age old late 60's design solutions from the smartest Detriot engineers, since the 2V 250 was an American spin off development, just like the first All Aussie 1972 Falcon was really a US design study which got done in the US first..
All this talk is talk about the solutions and 'things' that already exist.
When you compare to the Australian 2v way of moving the carb to the right verses the US log way of just fidling withthe air cleaner housings, a joint approach of doing boath allows you to fit a 2-bbl carb under the hood with ease.
In this, we have two methods of underhood clearance, the Aussie way, and the US way. Each have merrit.
http://i1215.photobucket.com/albums/cc5 ... aner-1.jpg
http://i1215.photobucket.com/albums/cc5 ... LEANER.jpg
As for me, the following are basic Paint alterations, but show the basic idea I tired to convey with as few links as possible
The 90 degree turned air cleaner is either a dual snorkel version of the cut and shut stock 3.3 item from the 80's, or the common Cobra item
