Very long and involved story made VERY short, the new DS-II dizzy I bought from O-Reilly's a few years ago was junk. I replaced it with one from a Maverick I found in a junkyard. And the JY dizzy made the newly rebuilt engine run TONS better than the "Cardone" re-mfg POS I got from O'R
. So I "re-curved" the JY one based on the sticky. I replaced the smaller wire spring. But when I went to move the post on the thicker wired spring it looked like there was a 3/32" gap already. So I moved it an additional 3/32" and basically found out the thicker wired spring never provided any tension on the post even at full advance! So.... with regards to the two springs, what is the setting coming out from the factory? Are both springs touching their respective posts? Are the posts moved 0.0XX" after they make contact with the spring(s)? Is there a gap between the spring end and the port?
Again to make a very long story short, I've discovered most of the drive-ability issues since the engine rebuild are mostly dizzy related and not the 3-4 different carbs I've tried! I"m hoping to settle the dizzy issues and move on to the carb next
Tanx 8)
Tanx 8)
