Mr Comet
Not sure where to start on this. I bought a 1974 carter RBS carb with an electronic choke. Here the info on the side of the choke:
EG902A
2J24B
B
2KT5-1V
I am not sure which was better this choke or the spring loaded only type. I am willing to listen to any feed back whatsoever. I am assuming this was wired via hot from the ignition going thru some heat sensor to the choke. Any ideas on that? Also when I reinstall the head on my engine do I use anything on the bolt threads? How about the bolt threads for the exhaust manifold?
EG902A
2J24B
B
2KT5-1V
