Mr Comet
Over this winter I made some changes on my 200 6. First a new clay smith 264 264 110 cam, with that came new lifters, 302 springs and dual timing set. With this I also added new '78 DS distributer and GM module. Head has been shaved .050 which I estimate puts me now at 8.9-9.0 to 1 compression. When I went to start it up for the first time today nothing but real slow turnover. Now all the new parts have new generous coating of assembly lube and the car sits in an unheaded garage today's temp is 25 degrees. My fuel pump works off the cam and so I have no fuel in lines or probably the bowl of carb. Since the distributor is new should I check for spark first or should I put some gasoline directly into the carb throat? Not sure where to start or should I just wait for warmer weather?
