<<< New Site Update >>>
Need good oil pan gasket
Jimwell150
Post #1 by Jimwell150 » Sat Jul 25, 2015 8:37 pm
What's the best oil pan gasket for a 67 200. It's leaking by the alternator.
wsa111
FSP Moderator
Re: Need good oil pan gasket
Post #2 by wsa111 » Sat Jul 25, 2015 9:23 pm
Felpro oil pan gasket set.
Make sure the oil pan bolt holes are not dimpled. To fix that you need to flatten them from the oil pan mating surface with a hammer.
I use grey permatex at all four corners where the rubber seals meet the cork gaskets.
Bolt the pan down & if the above is done correctly you will be leak free.
ludwig
Post #3 by ludwig » Sat Jul 25, 2015 9:47 pm
I clamped the edge between two pieces of 1x2. It doesn't deform the dimple at the holes and gets you a straight edge. You can saw it off for the ends of the pan. The other thing is to put it upside down on a piece of plywood to get a flat surface so the lip isn't twisted out of flat. And gasket sealer.
Users browsing this forum: No registered users and 12 guests
