I've got a 65 200 with adjustable rockers. Nearly everything is stock, with the exception of Pertronix. Yesterday, I had a water pump go from a slow drip to a sieve, and the car got a little hot on the way home. Not so hot the temp maxed out or the engine cut out, but still hot. Now, the idle is rough, acceleration is slow, like I am missing a cylinder. Engine smooths out at higher RPMs. I replaced the water pump, checked and replaced the plugs with a spare set, and am going to try replacing the wires with a spare set. Cap and rotor are pretty new and still look ok.
how likely is it I bent a pushrod or stuck a lifter from overheating? I suppose I could have also burnt/stuck a valve, but in times past when that has happened, I got tons of backfiring and blowby out the pcv hole.
