So after doing the math and with s&h I am pretty sure these things will run between $150-$175 a pop.
Now with that said, who is still interested?
rbohm":3d3y4hzm said:the best set up would be a bolt in kit, with a price of about $100. if you set it up with a multi key way crank sprocket, say 0-2-4-6 degrees advance and retard, so much the better.
BCOWANWHEELS":3v43a8b3 said:also rather than a india made chain I,d rather see a genuine Toyota chain. india stuff is junk
PS the Holden V8 3DR62 chain is the same as the Toyota 18R series motors. If you get stuck there's an alternative
Timing Chain and Gear Set, Magnum, Double Roller, Iron Sprockets, AMC, 290/304/343/360/390/401
NAPA 9-4026
NAPA 9-4058
REPUBLIC PARTS R2362
SEALED POWER 222-3DR62
SEALED POWER 222-906
AUSTIN 145870
MG MIDGET L4-1.5L Engine Timing Chain - 79-75
TOYOTA CELICA L4-1.9L Engine Timing Chain - 1971
TOYOTA CELICA L4-2.0L Engine Timing Chain - 74-72
TOYOTA CORONA L4-1.9L Engine Timing Chain - 70-69
TOYOTA CORONA L4-2.0L Engine Timing Chain - 74-72
TOYOTA HI-LUX L4-2.0L Engine Timing Chain - 74-72
TOYOTA MARK II L4-2.0L Engine Timing Chain - 1972
TOYOTA PICKUP L4-2.0L Engine Timing Chain - 74-72
TRIUMPH TR6 L6-2.5L Engine Timing Chain - 76-69
Part No TCDR62LE
Supplier Part No 3DR-62CL
Description 2 required T/CHAIN HOLDEN V8/TOYOTA 18R
LINK
Details 2 required
Category Timing Chains
OverSize
Brand Endurotec
MG Midget 1.5L 1493CC 91Cu. In. l4 GAS OHV Naturally Aspirated
Triumph TR6 2.5L 2498CC l6 GAS OHV Naturally Aspirated
Toyota Corona 1.9L 1898CC l4 GAS Naturally Aspirated
Toyota Corona 2.0L 1968CC l4 GAS Naturally Aspirated
NEW 'aftermarket' Hillman Hunter 1725 (1.7 litre) Double Row TIMING CHAINS $34.95 each
1725 cc, 1600 cc, 1500 cc engines
HILLMAN- Hunter, Minx, Super Minx, Husky 1955-1977 Double Row Timing chains
HUMBER- Sceptre 1962-1976 Double Row Timing chains
SINGER- Gazelle, Vogue 1959-1970 Double Row Timing chains
SUMBEAM- Alpine, Rapier 1956-1976 Double Row Timing chains
Chrysler Hunter 1977-1979 Double Row Timing chains
