Ok, Got the Comet all put back together with the new 200. Good news....started right up, runs smoothly. BAD news, two things: A tinny, echoing banging sound...all clues point to a rod/crank hitting the oil pan...the motor had been set on the pan when it was removed from the donor car, smushing in the bottom. I thought I had banged it out, but apparently not enough...hopefully that's all it is. SECONDLY, the motor is heating up too quickly and too hot, to the point of just quite overheating. I have a new water pump, thermostat, 180, temp sender. Water seems to be circulating by looking in the radiator, so 1st I will try the old sender, then take out thermostat, then I don't know if that doesn't work! Gotta love this hobby! Trying to figure out if I can drop the pan without removing the crossmember. Will use the pan off the 144.
