Rebuilding a 1967 Mustang 200 cid 6. Need to make some mods to the sump and pan.
Doe's anyone know. can I use a ford 300 cid oil pump on a ford 200 cid block? I need to use the side pick up tube attachmnet on the 300's pump, to install a rear sump pick up tube and strainer.
