Throttle plate question
cmm24601
Post #1 by cmm24601 » Sun May 07, 2017 1:58 pm
I have an Autolite 1101 on a 1969 250 Mustang, automatic
I have been tracking down a vacuum leak and the cigar test revealed smoke emitting from around the lever pump. sure enough. The entire throttle plate shimmies back and forth in the carb housing. I replaced the lever pump, but I'm sure of the best way to stop the leak, which is around the throttle shaft. It wiggles less than 1/16" but that can make a big difference, apparently...
I fashioned some c-clamps out of thin washers and added them to the small gap between the lever pump and wall of the carb. There was a noticeable improvement on performance, but it's still not air tight and I don't know how long those washers will last.
Has anyone come across this problem before? Is there something missing?
1969 Mustang Grande
250 inline 6
Automatic Transmission
Autolite 1101 Carb
wsa111
FSP Moderator
Re: Throttle plate question
Post #2 by wsa111 » Sun May 07, 2017 2:09 pm
You have to install a bushing in the base to eliminate the play.
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6425CL & MSD-Blaster 8252 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
B RON CO
Post #3 by B RON CO » Sun May 07, 2017 2:25 pm
Hi, X2. The throttle shaft is harder than the base and usually the base has some wear. Any carb guy can install bushings and ream them to the proper size. Good luck
1966 Ford Mustang - 289 V8
cmm24601
Post #4 by cmm24601 » Sun May 07, 2017 2:47 pm
By any carb guy do you mean me by my lonesome or a machine shop?
1969 Mustang Grande
250 inline 6
Autolite 1101 Carb
B RON CO
Post #5 by B RON CO » Sun May 07, 2017 4:56 pm
You can try to find the right parts, I'm sure someone here knows what will work. I mean an old fashioned carburetor shop. Allstate Carburetor by me on Long Island works on all carbs. I would find someone and just bring them the base plate. Good luck
wsa111
FSP Moderator
Post #6 by wsa111 » Sun May 07, 2017 8:41 pm
Allstate carbs are highly recommended.
If you or a friend is a machinist, check out Mike's Carburetor's for necessary parts.
woodbutcher
Post #7 by woodbutcher » Mon May 08, 2017 1:35 pm
:hmmm: Several years ago,on the hard core tech forum there was an excellent thread on totally redoing a carb.Including the worn shaft bore redo.Unfortunately,I don`t remember the name of the person doing the work.Great write up on the work including great pictures of the process.
Maybe one of the people here can remember who it was,and the name of the thread.If it still exists,it should be entered in the stickies.
Good luck.Have fun.Be safe.
Leo
Otto von Bismarck
chad
Post #8 by chad » Mon May 08, 2017 3:27 pm
"...the worn shaft bore redo…."
Yes! now THAT's a sticky if ever there wuz 1…
(use drill press?)
wsa111
FSP Moderator
Post #9 by wsa111 » Mon May 08, 2017 4:06 pm
I found the source for 5/16's throttle shaft bushings kits.
I just spoke with the fellow & you can order them on ebay or call him direct for the kit. http://www.ebay.com/itm/Carburetor-5-16 ... es&vxp=mtr
Here is the link for the topic on the forum. How do you like that Chad?? Bill
viewtopic.php?f=1&t=63239&p=483428&hilit=bushing#p483428
chad
Post #10 by chad » Mon May 08, 2017 5:10 pm
WoW
thnx Bill !
this 1 has a pic
fordsix.com//viewtopic.php?f=5&t=36077&hilit=some+carb+mods+application
a reamer'n bushing creates a DIY project!
Now
If I only hada way to re-jet an RBS (they're pressed in)…
Bringin ol stuff back to life ina beddah format than the oem!
(sounds like the ford6 way !)
:twisted:
woodbutcher
Post #11 by woodbutcher » Tue May 09, 2017 2:15 pm
:beer: Hi Bill.Many thanks for the search.Had that one bookmarked,BUT,the HDD in the computer that it was on took a dump and I lost everything. :thanks: :nod: IF that one could be put in the stickies or the archives,that would be a great help to all.I did`nt realize that that thread was almost 11 years old.
Leo
Otto von Bismarck
wsa111
FSP Moderator
Post #12 by wsa111 » Tue May 09, 2017 3:14 pm
Leo, post is in the tech part of the forum under Misc.
woodbutcher
Post #13 by woodbutcher » Tue May 09, 2017 7:15 pm
:D Hi Bill.Thanks for the heads up.I also bookmarked the thread in my favorites.He did some awesome work on that carb.
Leo
Otto von Bismarck
lahti35
Post #14 by lahti35 » Wed May 17, 2017 9:29 am
I'm doing this very thing right now... I was able to find a kit for a GM quadrajet carb that also has a 5/16 shaft and comes with 8 correct size bushings and reamer for about $30 on ebay.
Mikes carb's has the bushings but the OD is a funky size and I had a heck of a time finding the right reamer... I did find Oilite bushings in a standard OD off the shelf reamer size also. I ordered two to try with the GM rebuild kit as those are just brass... but splined on the outside for a tight fit.
Post #15 by bubba22349 » Wed May 31, 2017 8:31 pm
Thank you Bill glad to hear there is still a source for the shaft bushings. :thumbup: :nod:
chad
Post #16 by chad » Tue Jun 04, 2019 9:16 pm
cmm24601 wrote:I have an Autolite 1101 on a 1969 250 Mustang, automatic
Bump, bump...
Did you get anywhere?
Users browsing this forum: No registered users and 23 guests
