Years ago I got a edelbrock valve cover..it has a hole on the side,back of the cover..I found a Honda pvc valve with the grommet ..my question is do I run a hose from the pvc to the vacuum outlet on the head..I have seen some falcons that run the hose down the engine close to the ground..now I also have the offy with 3 Weber’s..
