timson
First let me say that this forum is awesome. Every time I look at it, I learn something new. I´ve been lurking and reading for many years now as I contemplate my rebuild, and now it´s time to act, so I thought I´d run some questions by you all. Thanks for the great reads, both online and in the Handbook, and the expert advice with minimal guesswork.
What I have:
´61 Comet with 170ci (my first rebuild in 1990, now with 100k miles) and 2-speed “cometdrive” tranny, stock 7.25” rear, 14” rims, manual (drum) brakes/steering. Electric wipers (aftermarket). Pulled her out of a 10-year storage last year and drove 500 miles to my home to begin upgrades. Just installed a dual-reservoir master cylinder, wheel cylinders and flexlines, with more improvements to follow.
• In addition to the above, I pulled a 200 ci (with Holley 1946 carb), a C4 tranny, and all I thought I´d need (according to the Handbook) from a 1982 Zephyr. Rebuilt the C4 (with mild shift kit) and am now starting on the engine. I plan on dropping both in the car this fall, adjusting the drive shaft, carb, linkages, etc. as necessary and enjoying!
What I want:
• daily driver; strong, economical highway cruiser; occasional towing of motorcycle trailer; I live at 2000´, but want to be able to take it from sea-level to 10,000´ using widely available 87-89 octane gas.
• Future mods: front end work (spindles, steering column), 1” stabilizer, exhaust system, 2bbl carb, etc.
Most of my questions and doubts have been answered by reading the Handbook and this forum, so again, Cheers! With the rebuild, I will reuse the adjustable rockers and pushrods, oil pickup, sump, and exhaust manifold from the 170. My end CR goal is 9:1. Unless the machinist indicates a problem, I will reuse stock valves on the large log head, but will do the grindings and polishing as recommended. Once new pistons are in, I´ll measure/deck block to 0 clearance, then mill head towards 9:1 CR.
I just took the dismantled 200 engine to the machinist. So far, he´s informed me I´ll need a .040” overbore on the cylinders. More info to follow. According to what I´ve read here and in the Handbook, several things stick out, and I´d like some confirmation or input from you all on the following items:
1. pistons: Flat or dished?
a. Since I have to overbore my block by .040”, I thought flat pistons would be a good way to help recover some compression, but it seems most folks here advocate dished for turbulence/combustion reasons. That true? If so, I´ll order dished and get on with decking and milling accordingly.
2. recommended cam: 164/174 w 112 lobe separation?
a. Based on reading input on this forum dating back to 2003, considering my goal of a 9:1 CR, and a motor that is easy idling, with low-end power and passing/climbing ability at faster speeds, this cam seems to get the most likes. Yes?
b. Currently, it seems Matt at Vintage Inlines is out of this size of cam, offering the 164/164/112* cam. Will that work as well and what should I know about the difference? With the stock exhaust valves, should I make an effort to find the 164/174?
c. What is the difference between “oiling” vs “non-oiling” hydraulic lifters offered by Matt and which are best for my application?
3. parts: I’m waiting to hear from Matt at Vintage Inlines about some of the items I need, and I’m psyched that there is a vendor who specializes in our 6-bangers. Since he doesn´t offer everything, however, what other suppliers are good sources for the parts I’ll need?
Thanks for any help you can provide. In the meantime, I´ll continue exploring the forum...
Cheers,
tim
			What I have:
What I want:
Cheers,
tim
