Rebuild 65 200 I6 Block.
echo1955
Re: Rebuild 65 200 I6 Block.
Post #151 by echo1955 » Sat Dec 18, 2010 1:48 am
Oil Ring Gap: 0.0
Scrapper Gap: .033
Both Compression Rings Gap .018
echo1955
Post #152 by echo1955 » Sat Dec 18, 2010 2:00 am
Old Rope Type Rear Main Seal:
I have ordered FelPro Rear seal # BS30135. I hope it is an PTFE type.. :?
Stay tuned…… more T/K
Post #153 by bubba22349 » Sat Dec 18, 2010 2:11 am
Looking good :thumbup: Though I don't care for the old rope seals if you can get a lip seal :hmmm: Give you back a bit more power too! :nod:
Even a bad day Drag Racing is still better than a good day at work!
Current project is a 1988 John Deere 420 Garden Tractor I need a few small parts to get it fixed, plus some cosmetic items, maybe a few attachments, if you happen to have or know of JD 420 parts would welcome the help!
My Ex-Inline 6 Fleet 1954 Customline 223 3 speed with O/D, 1963 Fairlane project drag car with BB6, 1977 Maverick 250 with C4, 1994 F-150 a 300 with 5 speed.
echo1955
Post #154 by echo1955 » Sat Dec 18, 2010 2:21 am
I would be scared to death using that rope seal and not having a leak...
I may be old but I love new technology .... :mrgreen:
I have ordered a new (Modern) seal... :mrgreen:
I'll show it when I get it..
Post #155 by bubba22349 » Sat Dec 18, 2010 2:42 am
A rope seal will work without leaking and last a long time. Still the later style seal's are just that much better! :nod:
echo1955
Post #156 by echo1955 » Sat Dec 18, 2010 4:45 pm
You are indeed correct as this seal has never leaked and it looked good when I took it our.
BUT
It was installed by a professional and I is certainly ant one O dem… :?
This will be my 4 rear main seal install and I don’t count the first 3 as that was 50 years ago and I had my twin brother helping…
So just call me chicken little cuz i dont mind.
I is going for what I consider the easiest… :mrgreen:
echo1955
Post #157 by echo1955 » Sat Dec 18, 2010 4:51 pm
I installed the oil rings for piston # 1-2-3 and 4 over the boss facing the thrust bearing pointing at rear of engine.
The # 5 and 6 over the boss facing thrust bearing pointing at front of engine.
The scrapers and compression rings at 45º relative to oil rings.
I use Quickseat on the cylinders. I believe you can see the cylinder walls are a greenish color.
wish me luck... :wink:
Post #158 by bubba22349 » Sat Dec 18, 2010 5:16 pm
Good luck keep up the excellent work. :thumbup: Years ago seen pictures of the special tool they made to install rope seals round stock with shaft to pound it in. I have always installed the rope seal's just using a big socket side ways to push it in and than tap it a gently with a hammer to seat it. After that trim ends with single edge razor blade or other sharp knife. Never had a new install leak. :nod:
echo1955
Post #159 by echo1955 » Sat Dec 18, 2010 6:06 pm
I'm gonna think about that. It's the cutting the ends that causes me concern..
If I'm to short or to long, slight angle ?????
Remember bubba, my craft was Publishing not motor building.. :mrgreen:
Post #160 by bubba22349 » Sat Dec 18, 2010 7:06 pm
It's real easy with a razor blade start at inside edge with blade about 30 degrees and resting on block’s parting line slice it back and forth as like a saw. It may take second cut to get it trimmed flat even with block. I know you can do it. :nod:
woodbutcher
Post #161 by woodbutcher » Sat Dec 18, 2010 9:08 pm
:D Hi echo1955.Just remember the wise words of my Grandfather."Slow and sure,beats quick and dead".
Leo
Otto von Bismarck
echo1955
Post #162 by echo1955 » Sat Dec 18, 2010 10:13 pm
Well how does this look… for starters..
This is as hard as I could push down on the crank and I see a crack at the bearings.
When I torque this down will it make a better seal at the end joints?
it took a half box of razor blades to cut this sucker..
if this dont look good enough , say so. ya ant going to hert my feelings.. :mrgreen:
echo1955
Post #163 by echo1955 » Sat Dec 18, 2010 10:45 pm
hahahahahh Hey woodbutcher… now that is funny.. heck I’m glad you asked why..
When we were kids my dad always told us..
“”Son in this world there are only 2 GATES…
The Fast Gate
And
The Slow GATE..
Both of you two boys are always coming out the slow GATE””
It wasn’t until after we got out of the Corps that we realized what that GATE was all about. He was an avid gambler on horse racing…. Darn good at it to..
So I is still always coming out that darn old slow GATE.
It has been drilled in me by someone that really knows the difference… :mrgreen:
Your Grandfather is steel on target… and I wont forget “”Better slow and sure..”” :thumbup:
woodbutcher
Post #164 by woodbutcher » Sun Dec 19, 2010 11:53 am
:( Hi echo.Grandfather passed on at age 85 in 1955.His first job in this country after coming here from Germany,was riding horseback and chasing Indians with the US Cavalry.
He had some tales to tell.
Leo
Otto von Bismarck
Post #165 by bubba22349 » Sun Dec 19, 2010 2:45 pm
That seal install looks good enough to me from over here :hmmm: Only other thing you might do is polish up the crank’s area were that seal rubs against (if the cam is in) than your ready to lay the crank and finish up the rest of short block. :thumbup:
echo1955
Post #166 by echo1955 » Sun Dec 19, 2010 3:54 pm
Thank you bubba…
I did notice the surface area and it did not have a worn seal type grove.
I didn’t think to polish it. I will use some emery cloth.
Good catch…. :thumbup:
The cam is in just waiting to settle the bolt issue with it... :?
By the way.. I will wait for the new rear seal to come in…
This rope seal has me on the ropes.. :mrgreen:
Post #167 by bubba22349 » Sun Dec 19, 2010 3:57 pm
:beer: :thumbup: Great keep up the good work :nod:
echo1955
Post #168 by echo1955 » Mon Dec 20, 2010 11:52 pm
Good oil priming tool for the early inline six.
Use the original oil pump Intermediate Shaft:
Use 1/4" 8mm 6 point socket:
Use Long 1/4” x 6” extension and cut the ratchet end off.:
Works grrrrrrreat… :thumbup:
You can get a new Intermediate shaft HERE
'68falconohio
Post #169 by '68falconohio » Tue Dec 21, 2010 12:13 am
Hey echo, the only thing I'd add to your oil-pump priming tool is some electrical tape to the joints. It really sucks when you drop a piece of it in the pan....BTDT.
'68 Falcon - sold
'99 F-250 Super Duty, '64 Lincoln SA-200 "Redface" - weldin' car
'04 F-350 Super Duty - racecar
echo1955
Post #170 by echo1955 » Tue Dec 21, 2010 12:27 am
hahahahahah heck man I hears ya... I did check to see I had a tight fit but I like the tape idea... :thumbup:
echo1955
Post #171 by echo1955 » Tue Dec 21, 2010 12:48 am
Hey '68falconohio.. hows this.. heck I feel better already and I tant even close to needing it yet..
If I drop this sucked down in the oil pan I will quit my new-found job of motor rebuilding… :mrgreen: :mrgreen:
'68falconohio
Post #172 by '68falconohio » Tue Dec 21, 2010 1:10 am
Looks like she'll work to me!
'68 Falcon - sold
echo1955
Post #173 by echo1955 » Tue Feb 01, 2011 11:21 am
I got my Carb (my new SC Valves), head and oil pan ready to bolt up.
Waiting on 3 carb Ofy manifold. Should ship 14 Feb?
Waiting on rocker assembly…
If I have to I will use my stock exhaust for break-in
Add the dual headers afterwards.. ??
Taking shape… :P
MPGmustang
FSP Moderator
Post #174 by MPGmustang » Tue Feb 01, 2011 12:23 pm
I thought you were going for the alum head, what's this tri-carb setup???
I'm jealous, oh so jealous...
65mustang-SOLD-200ci-t5-scarebird disks-vintage air ac-264/274 110 cam-mav 8inch 3.8 open-350cfm-CI headers
66 Bronco-SOLD-i6 170 - rust bucket never ran...
75 bronco-SOLD-v8 c4 dana 20 33's and disk brakes, locker front/rear.
Post #175 by bubba22349 » Tue Feb 01, 2011 4:20 pm
Aren’t you going to use a later distributor? IE like a 68 up points type, a DSII or DUI. If so the 1101 would be better chose and save you some work modding them. In the case that you are keeping the LOD dist. only the center carb needs a hookup the end carbs would be plugged.
echo1955
Post #176 by echo1955 » Tue Feb 01, 2011 6:43 pm
MPGmustang wrote:I thought you were going for the alum head, what's this tri-carb setup???
MPG it was always about Tri Carbs
The whole reasoning for this build was to go with a tri carb set up.
At that time mike said he would have a tri carb manifold ready before I was ready.
Well that did not go as plan. Mike doesn’t know when he will have a tri setup ready.
So I go with plan B.
That is with the log head modified and the ofy tri carb manifold.
I believe the Autolite 1100 will fit with out having to drop the engine or cut the hood.
I will machine a plug for the SCV… because I could not get 3 1100 w/o the SCV..
If and when Mike ever comes out with a tri carb manifold and I’m still kicking I will use it.
Mean while I have a Tri Carb set up with good eye candy and some increase in performance..
My original objective.. :mrgreen:
Man I'm so easy to work with... :mrgreen: :mrgreen:
echo1955
Post #177 by echo1955 » Tue Feb 01, 2011 6:57 pm
Yea I forgot to note that small 400.00 detail... :mrgreen:
I could get only one 1101 and I did not want to mix and match. I will be using a DUI.
I will also be running all 3 carbs as one unit.
I believe these carbs are rated around 180 CFM? So running all three together will allow me to get peak performance at all throttle from idle to WOT..
MPGs is not one of my objectives
whata ya thunk..??? :mrgreen:
Post #178 by bubba22349 » Tue Feb 01, 2011 9:59 pm
I have always liked a multi carb set up and especially tri power so my vote is too go for it, :nod: might be slightly more time at first to get the tune just right. :hmmm: You could always swap out the straight linkage for progressive if dose not work as well as you like. Have been hunting for a couple Holley 1904 cores (glass bowels) for the old 54 “223” six project it will also be straight linkage. :thumbup:
pikesan
Post #179 by pikesan » Wed Feb 02, 2011 1:15 pm
Hey Echo,
I'm over in Chandler, AZ near MPGMustang. I'll be rebuilding my 200 soon too, but going alot more low buck than you! I'll be watching this post to see how it all works out.
Good luck!
See all my cars here: Pikesan's Garage What's in your garage?
Gene Fiore
RC Moderator
Post #180 by Gene Fiore » Thu Feb 03, 2011 2:00 pm
Hey Roy...what's up with the black engine paint? Is that period specific for 1965 or do you just like black?
1971 Maverick, 250I6, crank knife-edged, Clay Smith 278 solid cam, .040 over 255 V8 pistons, 10.5 to 1, Custom 500 Holley 2V on Classic Inlines Aluminum cylinder head, 1.6 rockers, Hooker header, DUI dizzy, C-4 w/2800 stall, 8" 3.55 det locker
Best ET 1/4 mile: 14.92 at 89.61 mph on 1/12/2013
My Classic Inlines Photo Page
echo1955
Post #181 by echo1955 » Fri Feb 04, 2011 8:57 pm
Gene Fiore wrote:Hey Roy...what's up with the black engine paint? Is that period specific for 1965 or do you just like black?
Gene when i bought the car the engine was black... Only the air breather and valve cover was red...
So I just kept it black...
echo1955
Post #182 by echo1955 » Fri Feb 04, 2011 9:05 pm
pikesan wrote:Hey Echo,
Good luck!
Well don’t give up on me pikesan.. you just might finish yours before I finish. :mrgreen:
I still need the dual roller rockers, DUI and some cheaper parts…
(under 200 bucks) :cry:
Im in Surprise.. haven’t been here long enough to know where MPG and Chandler is…
It was all I could do to find Speed World and its only a couple miles from me… :mrgreen:
echo1955
Post #183 by echo1955 » Sat Mar 19, 2011 4:14 am
Double Flair 3/16 “ Break Lines
CobraSix gave me the idea to change my single cylinder master cylinder to a dual cylinder. Thank ya CobraSix.
I took pix of the change over but I cant find where I put them.
But CobraSix has a good review HERE
I used 3/16 “ CNF-3B Cunifer Alloy Brake Line from FEDHILL
The use of FEDHILL idea came from jdn21758. Thank you jdn21758 it works great…
I had the good fortune of growing up wid a twin brother. I could never tape and float an inside corner. I could never get a good double flair using the tube cutter.
My brother could tape and float an inside corner fast, sharp as a tack and smooth as silk. He could also make a double flair using the normal tube cutter with one eye closed, the other eye staring at me and laughing his (buttock) off.. at me.. :mrgreen:
Any way this is how I dun did it and I don’t see any leaks..
I started here.. Thank you CobraSix..
As you can see my tube cut sucked big time. So I fell back on my trusty ban saw. Good straight cut.
1: File burs off and straight.
2: File a good chamfer
3 & 4: I Used 500 grit and repeated 1 & 2:
The left image is flushed to top of fitting or miss slightly on the low side.
Right side with fitting in place and a drop of oil.
1: With fitting centered ready to shape this guy.
2: Compressed until fitting is flush with holding tool.
1: I removed the 1 st flair tool then applied oil to the head and compressed until I ran out of strength.
2: What I ended up wid..
Another look at the results. On the right side you can see the only mark the tool left. Not bad at all for me any way..
My Prototype. Man I like high-plooten words… Worked great.
A plastic bottle of liquid tape and I had a perfect form.
Finished and in place. Don’t look half bad..
echo1955
Post #184 by echo1955 » Sat Mar 19, 2011 4:22 am
Good luck!
Pikesan, I don’t know why I posted my tri carb offy in a separate thread.
But you can see some of what I did HERE
Post #185 by bubba22349 » Sat Mar 19, 2011 4:28 am
Looks good :thumbup: But is that a copper line? :shock: If so it's not a good idea for brake lines :nod:
echo1955
Post #186 by echo1955 » Sat Mar 19, 2011 4:44 am
bubba22349 wrote:Looks good :thumbup: But is that a copper line? :shock: If so it's not a good idea for brake lines :nod:
Hey bubba whats up.. :thumbup:
It's a different kind of copper I guess. :?
It is approved for USA break line service.
You can read up on it Here
JackFish
Post #187 by JackFish » Sat Mar 19, 2011 11:05 am
Nice job on the double flair, I always have trouble with that.
But I haven't used oil so that may be the ticket.
And a better tool would help too... :lol:
Is that copper brake line easier to flair?
Yup, I bought another one.
1996 Chevy Caprice 9C1 (3)
1999 Dodge Ram 2500
Post #188 by bubba22349 » Sat Mar 19, 2011 2:39 pm
Hi echo1955,
Interesting :oopsie: so thanks to you I learned about something new. :hmmm:
You are doing a clean job on your Mustang build up. Looks like you will be ready to go for a cruise real soon.
woodbutcher
Post #189 by woodbutcher » Sat Mar 19, 2011 4:17 pm
:) Hi Echo1955.Whats that motto?Ohhhhhhhh yeah.Inprovise and overcome.
Semper Fi,Marine.
Leo
Otto von Bismarck
echo1955
Post #190 by echo1955 » Sat Mar 19, 2011 5:23 pm
JackFish wrote:Nice job on the double flair, I always have trouble with that.
Hey JackFish.. how ya doing.. Better tool always make better helpers..
Light oil is an important key. Without it the flair gets small scarring and can leads to leaks and looks crappy to boot.
All I ever double flared before was steel and that was 30 years ago. I don’t recall it ever being to hard once I started using the ban saw. This copper looking line was easy but it took me some strength to get it.
Younger folks with more strength would probably walk right through it..
This is for sure. Shaping it is FIRM but walks circles around steel and forget SS.
echo1955
Post #191 by echo1955 » Sat Mar 19, 2011 5:32 pm
bubba22349 wrote:Hi echo1955,
hahahahahah hey bubba.. one of my firm beliefs… ya ant never to old to learn some’n new.
Y I learned some’n new just the other day that I never knew before.
I just dun forgot what the devil it was.. :? :mrgreen:
I’d like to take credit for that but I picked it up from jdn.. so thank again jdn.. :thumbup:
I'm looking at some time around June or July fer da cruse part. :beer:
echo1955
Post #192 by echo1955 » Sat Mar 19, 2011 5:48 pm
woodbutcher wrote::) Hi Echo1955.Whats that motto?Ohhhhhhhh yeah.Inprovise and overcome.
Semper Fi,Marine.
Leo
Well I don’t recall that one in particular Leo, but I do remember these:
Lead fallow or get da he*l out of my way.
And this one:
Do Or Die..
This one will probably be the last words out of my mouth before I takes me last breath.. :mrgreen:
Post #193 by bubba22349 » Sat Mar 19, 2011 6:38 pm
:thumbup: :nod: :rolflmao: yeah though sometimes I am probably a slow learner
:beer: X2
woodbutcher
Post #194 by woodbutcher » Sat Mar 19, 2011 7:02 pm
:beer: X2
Leo
Otto von Bismarck
jdn21758
Post #195 by jdn21758 » Sun Mar 20, 2011 1:38 pm
hallo echo you have find de cunnifer copper brakelines too,
this is nice stuff to work with,i have seen the photo's,,,,,,,,
nice job,,,,my friend.. :thumbup: :thumbup:
keep the good work on,i am enjoy you're project,
it makes me happy when i see those things,,,,,,
greeettzzzz,,,,,,JDN, :beer:
woodbutcher
Post #196 by woodbutcher » Mon Mar 21, 2011 1:01 am
:beer: Hi Echo1955 .Forgot to mention,that MC install looks factory.VERY nice.
Semper Fi buddy.
Leo
Otto von Bismarck
echo1955
Post #197 by echo1955 » Mon Mar 21, 2011 1:16 am
This is my PS bracket.. in it’s normal position
But it interferes with my DUI distributor. I need some clearance as seen in the photo.
By pivoting on the bottom bolt you can see where a new bolthole will go at #2.
Then I have to fabricate a piece at the top mount #1.
Then reshape the bottom mount at circle…
This should workout ok..
echo1955
Post #198 by echo1955 » Mon Mar 21, 2011 1:26 am
Hey jdn you may not believe this..
But…… I say BUT
One fine day I was just searching the web for a local Mustang Club to join here in the Phoenix area.
I accidentally tripped over the Classic Inline site thinking it might have some info on Classic Car Clubs.
One keystroke lead to another… then I stumbled into your thread with the Tri Carb Set Up…
Other than that
today I would be driving my boring Fastback to car shows with a dull 1v carb… :mrgreen:
So thank you again jdn… :thumbup:
echo1955
Post #199 by echo1955 » Mon Mar 21, 2011 1:30 am
Hey Leo
this ones for you..Image
:mrgreen: :mrgreen:
woodbutcher
Post #200 by woodbutcher » Mon Mar 21, 2011 8:14 pm
:beer: Outstanding.
Semper Fi Marine
Leo
Otto von Bismarck
