223 rockers
62bigwindow
223 rockers
Post #1 by 62bigwindow » Sun May 20, 2018 10:49 am
I want to put a Offy valve cover on my 223 in my '61. Is it possible to change the rockers to the 52-59 style with the studs that mount the valve cover? Is the cover wide enough to seal over the bolt holes that are used to mount the valve cover on the "newer" 223's?
Re: 223 rockers
Post #2 by bubba22349 » Sun May 20, 2018 1:10 pm
I haven't tried to do that swap though my best guess is that yes you could use the early style rockers and valve cover. Good luck :thumbup: :nod:
62bigwindow
Re: 223 rockers
Post #3 by 62bigwindow » Sun May 20, 2018 3:16 pm
Great. Its too bad there isn't another option. I think I'm going to have a side cover made out of a chunk of aluminum also. Now to find the Fenton manifold...
