I've done quite a bit of reseach on both, cast and steel. A cast header will handle the heat better, won't crack if its designed properly, will last much longer, and will be cheaper in the long run. The key is to hire a company with plenty of experience casting turbo headers. I've talked with such a company and have a bid, however it takes a confirmed order of 200 pieces to move forward. Unfortunately, with the economy being what it is, and slow sales, it isn't going to happen anytime soon.
