Here's a question, what's general opinion on compression ratio vs boost level limits for 200/250 turbo setup without alc/water injection ?.
My initial project is to test and learn with a low boost turbo setup on the 170 daily driver, with a swap to composite head gasket it should have a turbo-usable static CR @ 8.27 , then moving setup to a 200 I'm building. I'm unsure as to CR spec for boost levels and which engine and head to finalize the build specs. I can get CR down to @ 8.6 with a stock 200 and uncut 52 cc chamber heads, @ 7.7:1 IF I could find 62cc chamber head..
The stock 250 with 52cc heads is @ 10.6:1 but IF i could find a 70's 62cc chamber head the CR is @ 9.4:1 - still high for turbo'ing...
I have two complete running 200's with 52 cc head and a 250 long block also the Mav170 and performance 250 already in running cars.
thanks
thanks
