5 speed behind a X-Flow?
papawsfalcons
Post #1 by papawsfalcons » Fri Nov 29, 2019 5:34 pm
I want to put a 5 speed trans behind my X-Flow. Is this the same as an Americn 250? Thanks Ken.
Re: 5 speed behind a X-Flow?
Post #2 by xctasy » Fri Nov 29, 2019 6:42 pm
No. The Aussie T5 used from late 1985 to 1992 in Falcons and Utilities has a different Input shaft length to the US non world class or World Class, but good news is its easy to fit up a US T5.
The most common X flow bellhousing always has a unique block bolt pattern, and one of four types of trans bolt pattern.
Borg Warner 3- speed manual,
Single rail 4 speed,
5 speed Single Rail,
TopLoader 4 speed (only 1971-1974, non cross flow)..
The T5 is rare; most were automatics.
papawsfalcons
Post #3 by papawsfalcons » Sat Nov 30, 2019 5:26 pm
So I'm sorry what US parts can be used to put a T-5. Or? Thanks.
Post #4 by xctasy » Sat Nov 30, 2019 8:21 pm
What bellhousing do you have?
xctasy wrote:Borg Warner 3- speed manual,
You need an adaptor plate to fit your donar US T5 gearbox to the bellhousing you have.
There are several different input shaft lengths, non of them are the same as the Australian T5.
see https://fordsix.com/archive/www.classic ... Fswap.html
https://fordsix.com/viewtopic.php?f=76&t=1634
Greywolf wrote:Hi Jack!
I'm looking at an alloy X-flow, was wondering which bellhousing you used for your conversion to T-5 and how you handled the clutch slave?
I've been reading your Crossflow Chronicles but just want to make sure I have everything right in my head...so the best parts can be waiting when I get off this ship.
Thanks,
Ben
2/15/01
The T-5 adapter from California Pony Cars arrived today. It's simply a cast plate which locates the tranny in the bell housing, spaces the tranny out by about 3/4", and gives you a T-5 bolt pattern. The adapter requires that you drill two holes and tap one to mount the adapter. After that it just simply goes together!
T5 attached to the Crossflow top-loader
bell housing using a T5 adaptor plate
