2018 Contributors:
Performance Spark Plug Wires Worth It?
6ponies
Post #1 by 6ponies » Thu Jun 04, 2015 11:58 pm
I've just received my motor back from the shop. 200ci I6 from a '67 Mustang. They bored it .30 and zeroed the deck. We installed the aluminum head and will be installing a Holley 350 carb and DUI distributor. The question I have is regarding plug wires. I was looking at the LiveWires from CI and want to know if it's worth it (cost to performance). This motor was designed for daily driving and efficiency, not racing.
I suppose I should include plugs too. It seems from what I've read that unless I'm taking it to the strip, I should use stock.
1967 Mustang Coupe
200ci inline six
CZLN6
Re: Performance Spark Plug Wires Worth It?
Post #2 by CZLN6 » Fri Jun 05, 2015 11:26 am
Howdy 6:
I don't know specifically about the LiveWires you mentioned, but I do know that getting something from CI right now will not be possible. Do you have another source?
In general, a quality spark plug wire that advertises a Spiro Core, or Spiral core, that is custom fit, not cut to fit will do you just fine.
On spark plugs I usually buy whatever is on sale because I change plugs fairly often. For longer use I've had good luck with irridium plugs in the right heat range
YOu might want to outline the rest of your ignition system for best advice.
Hope that is helpful.
6ponies
Post #3 by 6ponies » Fri Jun 05, 2015 10:51 pm
I do have a source for other items.
So, here's the first dumb question....What else do you need to know about the ignition system?
Also, I suspect determining the heat range will be trial and error?
1967 Mustang Coupe
200ci inline six
