Im going to pick up an older 670cfm 2bbl Holley projection system.  Its used but is supposed to be complete including manual and was working fine when it was removed recently.   Im getting it cheap... to cheap to pass up even if Im not sure what to put it on yet.   I was thinking of putting it on my stock 200.   I have been told that they are easy to scale back and tune compared to carbs so size shouldnt be a problem.   From what I have heard the performance improvement is worth the trouble going to a 2bbl carb but the tuning can be a bit tricky so this is why Im thinking of this system.  Ultimately I want to go with something better with o2 and other sensors to make it run even better but for now Im hoping this will be a cheap toy that will be fairly easy to make work
Anyone tried it? All I could find in a search was talk about the 1bbl version they no longer offer.
Thoughts? Ideas?
Thoughts? Ideas?
		 IIRC,that unit(HolleyPro-Jection)came out in the mid 1980`s.
