Can someone tell me that. How small is this thing? Will a well tuned Tempo TBI make more power or less power than a well tuned Weber 38/38?
fordconvert":2a88kl3l said:I have read that most TBI style injectors start having issues around 20 psi. .....
fordconvert":1n6xwslo said:I have read that most TBI style injectors start having issues around 20 psi. In theory around 150 hp is about all you are going to get out of any single injector. Once you get above about 35 lbhr they start getting expensive. Over 50 lbhr are kinda rare and even more money. The GM tbi's are by far the most common ones out there. Most of them are around 60 lbhr IIRC.
The tempo (like most TBI's) use a side flow injector. Fitting a more common bosh style would be a lot of work, I think you would be better to just start over. There is or was a guy or company making a thing that looked like a 50's rochester with a single bore and to injectors hidden under what was the bowl.
