Sealing -AN plumbing???
falcon fanatic
Post #1 by falcon fanatic » Mon Jun 01, 2015 1:49 pm
Hi Y'all,
I'm doing a fuel injection conversion on my Falcon and I'm using -6AN hose for the plumbing. I'm wondering what kind of thread sealant I should use on these connections. Any advice?
'63 Futura Convertible. Disc/drum, Bilsteins, beefy swaybars, #480 springs, roller or spherical everything up front, HD shackles on stock springs out back. Megasquirt FI on ported, big valve aussie head w/ roller rockers; 10:1 6000rpm engine; 264/274-12*; C-4, Maverick 8" 3.25 W/trac-lok and perimeter frame inside the unibody. More to come...
http://falconfanatic.blogspot.com/
motzingg
Re: Sealing -AN plumbing???
Post #2 by motzingg » Tue Jun 02, 2015 5:19 pm
none!
they seal on the flange face, don't use any sealant but make sure the seats are clean with no scratches or nothin.
falcon fanatic
Post #3 by falcon fanatic » Tue Jun 02, 2015 9:39 pm
Really? Metal to metal? I can see that 37* flange looks mighty special, but really? I'm not talking about the hoses but the screw-together junctions: hose to fuel rail, hose to pump, hose to pressure gauge, etc.
garyt120r
Post #4 by garyt120r » Wed Jun 03, 2015 6:09 pm
AN fittings are routinely used in 3000psi aircraft hydraulic systems. No thread sealant used. You'll b fine with a 45psi auto system.:)
falcon fanatic
Post #5 by falcon fanatic » Thu Jun 04, 2015 1:38 pm
Great news!
falcon fanatic
Post #6 by falcon fanatic » Sun Mar 13, 2016 7:07 pm
For the record that was correct. these seal perfectly.
RichCreations
Post #7 by RichCreations » Mon Mar 14, 2016 6:16 am
falcon fanatic wrote:For the record that was correct. these seal perfectly.
they almost never leak, unless over tightened
