Jeep 4.2 Stroker High Performnce Build
jeepracer
New Member
Post #1 by jeepracer » Fri Jun 03, 2011 11:16 am
Hi all, im new to this forum and i have a question about building my 4.2 liter amc engine. I do alot of off road 4x4 racing and the jeeps not fast enough. i was looking to build a high performance 4.5 stroker. my questions are, can i get a custom high lift "roller" cam? High performance rods? and high compression pistons?
Any ideas?
80broncoman
Re: Jeep 4.2 Stroker High Performnce Build
Post #2 by 80broncoman » Sat Jun 04, 2011 3:58 pm
Not sure if anyone has done a roller cam in a 4.0 block or not. if so that will probibilty be where the biggest chunk on money goes if it you find one.
I am unsure about the different rods as well.
I do know people make pistons though.
What is your HP/Torque @ what RPM goal on this engine?
planning on EFI or Carb??
OAPSE Union Member
Real men don't wear Bowties
jeepracer
New Member
Post #3 by jeepracer » Sun Jun 05, 2011 10:04 pm
id like to make around 400hp. its going to be a full out race motor. rpms can go as high as it can handle. not sure what the cranks good till.
DaGr8Tim
Post #4 by DaGr8Tim » Thu May 02, 2013 4:06 pm
Check out jeepstrokers.com.
I found a 258 that I was going to stroke my 4.0 to 4.6. Then the guy turned around and offered me a deal for the whole Jeep, and I jumped on it.
A)bort, R)etry, I)nfluence with large hammer
1997 Jeep Cherokee
1975 Jeep CJ5 with a hacked CJ7 tub
BIG 6 farmer
Post #5 by BIG 6 farmer » Sun May 05, 2013 3:47 pm
Seems one popular upgrade on a AMC 258, is to bolt on a Cyl. Head off of a newer 4.0 Jeep. Even better to use the later version. another bonus is, you get rid of the plastic Valve cover mess.
DaGr8Tim
Post #6 by DaGr8Tim » Sun May 05, 2013 4:23 pm
BIG 6 farmer wrote:Seems one popular upgrade on a AMC 258, is to bolt on a Cyl. Head off of a newer 4.0 Jeep. Even better to use the later version. another bonus is, you get rid of the plastic Valve cover mess.
Another popular way is to throw a 258 intake on a 4.0 and convert it to carb. If it were me, I'd go that route and stroke the 4.0 out to 4.6.
1997 Jeep Cherokee
BIG 6 farmer
Post #7 by BIG 6 farmer » Sun May 05, 2013 5:53 pm
?? is, Does a performance Intake for a 258 fit on a 4.0 Head? Seems i read that using the later 4.0 Cyl. Head, is quite an improvement over the old 258 Head. Also thought they liked to fit a 258 Crankshaft in a 4.0 Block, to get a 4.5? Stroker. Problem with building a Stroker Engine, is it gets very expensive too fast. ( unless your talking a V8 Chevy, or some Fords). Going from a 4.0 or 4.2 (258). To a 4.5, or 4.6, isnt much of a gain for the money needed to get it done. My guess for a build, would be an overbored 258. With a late 4.0 Cyl. Head, Good Intake & Carb. Header. Im sure you can still get a lot of performance Flat Tappet Cams for a 258. Maybe somebody makes Roller Cam Kit? If they do, im sure the price is outa sight ! :bang: Building an AMC is like building a Mopar, twice the price. Look on sites & Forums for 4.0-4.2 jeep Engine Builds. :nod:
DaGr8Tim
Post #8 by DaGr8Tim » Sun May 05, 2013 9:57 pm
BIG 6 farmer wrote:?? is, Does a performance Intake for a 258 fit on a 4.0 Head? Seems i read that using the later 4.0 Cyl. Head, is quite an improvement over the old 258 Head. Also thought they liked to fit a 258 Crankshaft in a 4.0 Block, to get a 4.5? Stroker. Problem with building a Stroker Engine, is it gets very expensive too fast. ( unless your talking a V8 Chevy, or some Fords). Going from a 4.0 or 4.2 (258). To a 4.5, or 4.6, isnt much of a gain for the money needed to get it done. My guess for a build, would be an overbored 258. With a late 4.0 Cyl. Head, Good Intake & Carb. Header. Im sure you can still get a lot of performance Flat Tappet Cams for a 258. Maybe somebody makes Roller Cam Kit? If they do, im sure the price is outa sight ! :bang: Building an AMC is like building a Mopar, twice the price. Look on sites & Forums for 4.0-4.2 jeep Engine Builds. :nod:
From what I understand, you can use a 258 intake on a 4.0 head if you use an aftermarket header.
1997 Jeep Cherokee
Ford 6-4u
Post #9 by Ford 6-4u » Tue May 07, 2013 3:27 am
HESCO JEEP PRODUCT sells a aluminum head for the six cylinder jeep. This head flows 260 cfm at 28 inches "according to Stan Weiss site". This should get you 400 HP around 7000 rpm with a 258=6 cylinder, "depending on VE." 4550 piston feet per minute is a lot for any jeep. BUT POSSIBLE. Use the best of everything. I spun a 4 main bearing Ford 6 on the El Mirage lake bed at 4300 piston feet per minute for five years. Only problem was a occasional loose fly wheel. Go for it and keep us informed!
