edgewood bronco
Anybody have a recommendation for an additive to keep the coolant passages from rusting? When I dumped the coolant, it was RUSTY. Would like to keep that from happening if possible.
Thanks!
Thanks!
Lots of luck.Prestone Radiator Anti-Rust with Water Pump Lube improves cooling system efficiency and protects water pump life by reducing friction and protecting against rust and corrosion. Apply Anti-Rust with Water Pump Lube after each coolant change to guard against cooling system corrosion.
Anti-rust coat helps protect key cooling system metals from corrosion
Extends the life of water pumps and cooling system components
Compatible with all types of antifreeze
edgewood bronco":2u30yhgp said:Thanks. I put new in, but must've used some pretty crappy stuff. it was rusted after 600 miles. I'll pick some stuff up on my way home and get it right.
