250 Build in 67 Mustang
Georgia200
Post #1 by Georgia200 » Fri Jan 11, 2019 11:15 am
My block and crank are at the machine shop. Looks like .030 over, I will know for sure next week.
Time to put my build plan on paper and start ordering parts. My goal is to be on the road by spring.
67 Mustang coupe
DD / week end cruiser est: 3000 miles a year, mostly in town and on country roads
C4
2.79 gears
AC
PS
Georgia200
Re: 250 Build in 67 Mustang
Post #2 by Georgia200 » Fri Jan 11, 2019 11:33 am
I see three separate areas: Bottom end Head / exhaust
On the bottom end Im thinking OZ 3332H pistons and Taurus E63E-B1A rods. The rods are on ebay used pretty often, Summit for the pistons.
I do not want to mill the block so CR adjustment will have to be made with the head gasket and combustion chamber volume.
How much CR can I run with 91 octane/10% ethanol?
Stock oil pump
DS11
1965 fuel pump because I like the filter and I already have a new one.
What cam? I want a smooth idle.
I have a C9DE-M head. I have a new 1100, but if my machine shop can mill the head for a 2100 at a reasonable cost, I will do that. Stock valvetrain, I dont want to mess with adjusting valves.
Im planning on the stock exhaust manifold or a single outlet header. I have no idea how a header will interfere with the starter and alt/ac bracket. I have a C90A-2882 C alt/ac bracket.
Cam recommendation? Will it be different for a 1100 or 2100? Compression?
chad
fresh 250 Build-machining/assembly ideas
Post #3 by chad » Fri Jan 11, 2019 12:38 pm
starting to get confused (easliy done). Is this the same post elsewhere?
I think 1 way to reduce is by IDing CR 1st, go fr there...
The CR comes frm that ol time fav of all automtive Qs "What's the final application?"
Do U have "the Hanbook"?
"...How much CR can I run with 91 octane?..."
average 9.5 I'd say but it not done ina vacum there's (timing, cam, etc too).
Georgia200
Post #4 by Georgia200 » Fri Jan 11, 2019 1:13 pm
New thread to focus on the engine build alone.
Yes I have the handbook, very useful but dated in the sense that the internet contains much more information.
I thought I was clear on "What's the final application?" DD / weekend cruiser, I can add no track, no high rpm, just a nice driver.
I asked what CR i can run on pump gas with 10% ethanol.
The CR is a big question, as I think more about it, I realize that I need more information.
I have (2) C9DE - M heads. one of them untouched, one of them IDK. In either case, I doubt I will be able to keep the stock 62cc combustion chambers, so I need to ID that value first. Assuming 8.8-9.3 final CR, I may keep my stock rods and run flat tops.
Still need some opinions/guidence.
Post #5 by bubba22349 » Fri Jan 11, 2019 1:52 pm
The trouble with building a 250 is the amount of Quench or pistions being so far down the hole (from .123 to .150 down the bore depending on year). Stock these 250’s can be at 8.0 to 8.5 to 1 C. R. with a few real early 250's (1969-71) maybe a little bit more. Hope you did or can take some measurements of pistion height distance of #1 & #6 pistions at TDC, during the tear down so you know we're you starting from. Ideally in a Hi Performance build up we would want to see around .035 to .050 of quench, the two most current available head gaskets are FelPro at about .050 and Victor at .044.
Because 250's can become detonation prone when you start raising the compression ratio higher, only cutting the head to get the compression ratio up isn't really the best plan action for a 250 when using the stock rods and pistons. As you stated in your first above post you had planed on using the longer Taurus E6 conecting rods, at 5.99 lenght that is really a solid choice along with a good choice in a piston. Currently one site member is also doing that exact plan to get get much closer to the ideal of a zero deck height.
Another rod choice that can be used is the 300 big six Rods they are 6.2097 in length with early 1965 to 69 rods having a .912 small end pin size and the later ones being .975. Usually these rods require a custom piston but I haven't checked pistion catalogs in quite some time so there maybe an off the shelf piston available and there are a number of people on the site that have went with a 300 Rod using custom pistons.
Otherwise 8.8 to 9.3 (running on 91) would be is a decent goal for a daily driver, the bigger 250's can also handle a bit more cam than the smaller 200, around a 264 advertised duration for your DD goal, but you can get just what would be the very best for your exact combo with a custom ground cam by calling Jerry at Schinndler racing cams, plus it costs the same as a off the shelf cam (see below link). Your starting out doing it right asking questions and forming your plan, good luck. :thumbup: :nod:
Scheider Cams
http://schneidercams.com
Georgia200
Post #6 by Georgia200 » Fri Jan 11, 2019 9:57 pm
I couldnt rotate the engine before teardown. Rust in the cylinders and a couple broken rings.
I will mock up the old pistons when I get it back to check piston height.
I dont think zero decking a 250 block is a wise move for the long haul. That doesnt leave you any room if you need to true the head in the future.
This is a D2DE block.
CZLN6
Post #7 by CZLN6 » Sat Jan 12, 2019 11:47 am
Howdy Back Georgia and All:
Aah, good memories. My 250 build was a few years ago now, but still remember the stress of juggling all of the variables. I ended up with a 9.75:1 CR because I'm at 5,000 ft elevation. I used stock rods, with the beams polished and ARP rod bolts. I had the crank assembly balanced. I milled the block .070". I had the crank off set ground to gain a little more stroke.
I chose a 260 Comp cam, which was one of the best available at that time. If I were doing it today I'd follow Bubba's advice and call Jerry. Be sure to point out the high rear end gear you are planning on. In general, I thing you will want a torque cam.
For your driving description, IIWIYS, I wouldn't stress about the quench. I would stick with dished pistons for their less prone to knock quality. That leave you with milling the head to achieve your goal CR. Maximizing quench is a high performance, best practice. It doesn't sound like you are doing that, so build to your need.
Anyway, enjoy the journey and keep us posted on what you decide on.
pmuller9
Post #8 by pmuller9 » Sun Jan 13, 2019 3:42 pm
CZLN6 wrote:Maximizing quench is a high performance, best practice. It doesn't sound like you are doing that, so build to your need.
I don't post on the small block side very often but I saw this statement and felt the need.
Maximizing quench is very important in a street application where you are limited to pump gas octane.
The tighter the squish distance the higher the quish velocity for turbulance and the cooler the quench effect.
This becomes more critical when you are using a short duration cam for low end torque and want to push the DCR for overall efficiency especially for those of us that live closer to sea level.
On a different note, if you are looking for a smooth idle and performance use a cam that has a 112 degree Lobe Separation Angle.
Firebolt
Post #9 by Firebolt » Mon Jan 14, 2019 3:06 am
I would go with zero deck and .044 Victor gasket and if you have to mill your head later use the FelPro .050 gasket. Or at least that's my plan with 200.
Georgia200
Post #10 by Georgia200 » Mon Jan 14, 2019 6:44 pm
Zero decking is a problem if the head has been milled or will need to be milled in the future.
If I can find a couple unmolested heads, Im sucking them up for spares. There cant be that many left.
bmbm40
Post #11 by bmbm40 » Mon Jan 14, 2019 7:15 pm
Yes sir that is a good strategy. I have a whole spare 250, 1979 I think, and a 200 with the big hex log head. I am currently looking for a late 200 with the big bell and another 250.
pmuller9
Post #12 by pmuller9 » Mon Jan 14, 2019 10:18 pm
Would it be reasonable to use the stock 5.88" long rods and have AutoTec supply pistons with a 1.63" pin height and around a 15cc dish?
No machining to get zero deck and the compression ratio would be around 9:1 depending on head gasket and chamber volume.
Have Schneider make a 270H cam with a 112 LSA.
The DCR would be 9.2 to 9.3 and run nicely on 91 octane fuel with a little room to spare.
Econoline
Post #13 by Econoline » Mon Jan 14, 2019 10:41 pm
You can zero deck a 250 if you do it with different rods and pistons. I wouldn't get there with decking 60-100 thou. If the piston has a dish that will allow say 8:1 DCR or less with a stock or low duration cam and 56cc chambers, you're going to be just fine regardless. It's all in the planning and you're starting from scratch. So if you used .912 240 rods or HSC rods and custom pistons with a D dish matching the chamber in 13 or whatever cc was needed you could run an aluminum head if you wanted to AND have descent quench effect. Theoretically you could probably come out of the hole at ~.010-.015" with the gaskets available and still not interfere with the valves, depending on the lift and chamber depth and get the quench down below .040". You'd have to be real careful about that of course.
The HSC rods are the way to go iirc, too little piston left with the 240 rods or something. I'm a little fuzzy on the details right now. I remember thinking after lavron started his build that those rods with a custom piston could solve all the problems associated with the long stroke 250 and the heads available today. He's got a great build going. I think he's going with aussie hypereutectic 13cc dish pistons. The advantage of custom pistons is you can get exactly the size and shape of dish you want/need.
It ain't gonna fix itself
powerband
FSP Moderator
Post #14 by powerband » Tue Jan 15, 2019 9:13 am
A less known option to achieve Zero decking on a 250 uses AMC 258 pistons with stock rods. The rods small end only needs slight enlarging .
from previous post:
Ford 250: bore = 3.68 / comp distance = 1.5 / dish volume = 13cc
AMC 258: bore = 3.75 / comp distance = 1.633 / D-Sump = 21cc
This puts the bore at @ .070 over and raise the piston toward the deck .133 . The specs list the pin diameter of the ford at .9122 and the AMC's at .9310 which can easily be accommodated.
The cc volume of the recess is 21ccs- which makes it ideal for this application. With the .070" overbore the bore is 3.75", stroke of 3.91, a Felpro head gasket at .050", a zero deck height, chamber volume of 60ccs and a piston recess of 21 ccs, gives a compression ratio of 8.8:1.
The 61 Comet with AMC piston 250 has run reliably for over ten years with full power track launches and long distance interstate cruising. Two years ago the head gasket blew between 4 / 5 . With repair I got to inspect the still crosshatched cylinder walls and it appeared the Head work around valves thinned comp. chamber 4/5 near gasket .
rocklord
Post #15 by rocklord » Tue Jan 15, 2019 9:36 am
Econoline wrote:You can zero deck a 250 if you do it with different rods and pistons. I wouldn't get there with decking 60-100 thou. If the piston has a dish that will allow say 8:1 DCR or less with a stock or low duration cam and 56cc chambers, you're going to be just fine regardless. It's all in the planning and you're starting from scratch. So if you used .912 240 rods or HSC rods and custom pistons with a D dish matching the chamber in 13 or whatever cc was needed you could run an aluminum head if you wanted to AND have descent quench effect. Theoretically you could probably come out of the hole at ~.010-.015" with the gaskets available and still not interfere with the valves, depending on the lift and chamber depth and get the quench down below .040". You'd have to be real careful about that of course.
The 240 rods are 6.79" long and wouldn't work in a 250 unless you could find pistons with a 0.724" CH. Highly unlikely.
The 2.5 HSC rods (5.990") would be a good way to go. With a stock 1.50" piston, the recess would only be 0.024".
The rod ratio would increase to 1.532, a lot better than the stock 1.50.
Dan
Currently Own
1965 Mustang, 200CID, 3Spd
2017 BMW X3, 3.0L Dual Turbo, 300HP, 8-Spd Auto
65-coupe
Post #16 by 65-coupe » Tue Jan 15, 2019 5:06 pm
I have a brand new Schneider cam and oil through lifters I will make you a good deal on. I bought it for my 250 build but decided to go with a bigger cam with my alum head. It would be a great street cam for you with good low end TQ. Link to cam http://schneidercams.com/262-82HfordI6hydraulic.aspx
Brian
1965 Mustang coupe, SPI Orange with custom TMI interior, 250 DUI, CI alum head ported, 274/274 110 Clay Smith cam, 1.65 roller rockers, Holley 390 4bbl, Lokar pedals and throttle calbe. Street or track front coilovers suspension, CI headers stainless with Jet-Hot ceramic coating, CI Stainless 2" impostor dual exhaust, 17x8 Coys C-67 wheels,
Georgia200
Post #17 by Georgia200 » Tue Jan 15, 2019 9:52 pm
My block is a 74. How much overbore can it tolerate?
The problem with AMC pistons is that you need a virgin head. A zero deck, 258 piston. .050 gasket and a 54cc head yields 9.4:1 CR.
No room if you need to true the head in the future.
Same engine with a 60cc head nets 8.86:1 CR.
Brian, I am not yet ready to buy a cam but will keep you in mind.
Im waiting for the machine shop to give me the all clear on the block.
65-coupe
Post #18 by 65-coupe » Tue Jan 15, 2019 10:23 pm
Georgia200 wrote:My block is a 74. How much overbore can it tolerate?
Okay I have extra 250 blocks if you need one. But I would think yours will be fine.
pmuller9
Post #19 by pmuller9 » Tue Jan 15, 2019 10:58 pm
Would you be willing to get a custom piston form AutoTec and get the exact pin height and dish volume needed for zero deck and correct compression ratio?
Post #20 by bubba22349 » Tue Jan 15, 2019 11:38 pm
Here are a couple 250 builds of site members that might be of interest for you. This first one is the link to Lavron's budget 250 a mild build up (for his Comet) he's using the E6 5.99 rods with off the self pistons these conecting rods are .110 longer than the stock 250 rods at 5.88 so they go a long ways to help close up the quench distance. viewtopic.php?f=1&t=77057&hilit=Budget+250
Here is link to a 250 using the 300 rods (for a 1969 Mustang) with I think the custom Autotec or Racetec Pistons a more Hi Performance combo street / drag build up. viewtopic.php?f=1&t=74039&p=569484#p569484
Good luck :thumbup: :nod:
fast64ranchero
Post #21 by fast64ranchero » Thu Jan 17, 2019 10:40 am
OP, I'm not understanding your opposition to decking the block? I do understand you are not wanting to Zero Deck the block, but you can have the block decked as much as needed to get the compression you want with whatever head you use. Does that make sense?
example: you want 9.2 to 1 static compression, depending on rods and pistons used you may end up needing the piston -0.30 in the hole, so you have the block decked to that spec. later if you need to surface the head you can and it will only slightly increase compression (0.007 off the head will raise CR to 9.3) Check out this Compression calculator run you numbers. I think you will find you are too worried about a minor detail.
http://www.diamondracing.net/tools/
Walt
63 Ranchero,1965 Mercury Comet Convert V-8, 1978 Fairmont small six, mill'd off intake, 62-1 ET 12.332 @ 123.49 mph (gone)
CZLN6
Post #22 by CZLN6 » Thu Jan 17, 2019 1:51 pm
Howdy All:
My computor died. Sorry for the delay in responding.
Pmuller- I don't disagree with you in most cases. The getting a zero deck height on a 250 is either or both complicated and/or expensive. Having built a street performance 250, I've been there. I choose to deck the block .070", use stock dished piston and did minimum milling of the head. I did smooth and polish the combustion chambers. Even at that I ended up with a 9.75 CR, which was all right for my elevation (5,000') and gearing (3.2:1). I ended up with an .080" deck height- not optimal for deck height and quench but way better than the .150" deck height I started with. I also ran a Comp 160 cam which helped to control cylinder pressure. It had great torque, good mileage and an almost smooth idle. This combo gave me all the performance I wanted and no knock, and on regular gas most of the time.
Since Georgia does not want to deck the block, custom rods and piston and opening the combustion chambers are the other way to get to a more effective quench effect. $$$$$$$$$$ in parts and machining.
So, Georgia, what did you decide to do with the block build?
Post #23 by bubba22349 » Thu Jan 17, 2019 10:41 pm
:shock: I only hear the cricket's now! :nod:
Georgia200
Post #24 by Georgia200 » Fri Jan 18, 2019 8:02 am
I replied, but somehow it disappeared.
Its all a moot point until I get the block back and the machine shop tells me how far the pistons are down.
Its been a week, Im stopping by this AM to see where he is at.
I will be out of town this weekend and passing by a couple pull-a-parts. If I can find an E0 head, Im snagging it.
Georgia200
Post #25 by Georgia200 » Sat Jan 19, 2019 2:19 pm
My block came out of the degreese tank and is soaking in evaporust.
Monday he will start work on it.
No luck on an E0 head, looks like my C9 head will have to do.
Georgia200
Post #26 by Georgia200 » Sun Jan 20, 2019 10:53 pm
Disassembled the head today.
I dont think the head was ever off the engine.
Im planning on new everything.
I can buy a reman big log head for $400 + shipping from the west coast. Easy enough to install new springs, better seals and backcut the intake valves.
I could save my virgin C9 head for a spare.
Georgia200
Post #27 by Georgia200 » Thu Jan 24, 2019 7:18 pm
Rats
Ive been working a couple hours a day in the garage getting all the engine odds and ends ready for paint/install.
I started on the oil pan yesterday. It had a lot of grease and sludge on it, cleaned all that off and dropped it in the vinegar bath last night.
Pulled it out today for a look over and found that the drain plug is stripped and the bottom has rust through holes.
I dont think a new 250 oil pan is available so its more internet surfing to locate a decent used one.
I feel like Im spending more time online than I am spending actually working on the engine.
chad
250ci (2 yrs early) ina 67 Mustang
Post #28 by chad » Thu Jan 24, 2019 8:16 pm
Georgia200 wrote:I feel like Im spending more time...than I am spending actually working on the engine.
no matter the endeavor, 'the lill stuff', prep/wrap up, All Ways seems (well, in actuality it duz!) to take the longest.
Welcome to da make-it-happen worl.
(What's Econo say? "It aint...")
65-coupe
Post #29 by 65-coupe » Fri Jan 25, 2019 5:23 pm
I have one I can sell you. I am on vac so when I get back on the Feb 3 I can get pics.
Georgia200 wrote:Rats
Georgia200
Post #30 by Georgia200 » Fri Jan 25, 2019 8:23 pm
Thanks, I will be here.
Checked on the block today. Its still soaking in evaporust, the crank is still in degreaser.
Im working on the head this weekend and starting my 5 lug swap.
Georgia200
Post #31 by Georgia200 » Thu Jan 31, 2019 11:51 pm
The Weekend of the 8th I have to go to Fort Pierce, so I will pass by your way.
woodbutcher
Post #32 by woodbutcher » Fri Feb 01, 2019 10:28 pm
:hmmm: If you are going to be in Ft Pierce,you might want to check out the UDT meuseum(?) on North Beach if you have time.I grew up just up the road in Vero Beach.
Good luck.Have fun.Be safe.
Leo
Otto von Bismarck
Georgia200
Post #33 by Georgia200 » Sat Feb 02, 2019 6:04 am
Thanks, didnt know that was there. I also drive right by Big Daddys Museum.
Machine shop hasnt started on the block. Its still in Evaporust. These guys are older and working out of a shop behind the house. They will get to it when they get to it. I dropped the old pistons off so they can tell me how far down in the hole they are sitting. I still dont know what rods and pistons Im using.
In the mean time I received all my brake parts and am just about ready for the conversion to 5 lug power drum brakes. I ordered a set of 215-75-14 WWs that may be in today to go on a set of 14x6 Torino GT wheels with my stock hubcaps. Today Im going to the Pull-A-Part to get a set of 4.0 valve spring retainers, I cant find them new anywhere, a 5 lug spare, and some spare lug nuts. Im also stopping by Summit to get axle seals and bearings.
The parts pile is growing, time to open the tool box and get to work.
65-coupe
Post #34 by 65-coupe » Mon Feb 04, 2019 3:28 pm
When will you be in Florida?
Georgia200
Post #35 by Georgia200 » Mon Feb 04, 2019 9:49 pm
This weekend.
woodbutcher
Post #36 by woodbutcher » Mon Feb 04, 2019 11:14 pm
:bang: Hi Georgia200.I screwed up.It`s on South Beach.Sorry.Most anyone should be able to give directions.
Leo
Otto von Bismarck
chad
ocala & n. Hutchenson Is
Post #37 by chad » Mon Feb 04, 2019 11:28 pm
good its not wk of 17th, big vacaion wk. But
the SEALS'n big daddy Gerlis could B anothe kinda va-ca...
65-coupe
Post #38 by 65-coupe » Tue Feb 05, 2019 2:33 pm
Georgia200 wrote:This weekend.
I am off this weekend so let me know if you want to confirm by.
Georgia200
Post #39 by Georgia200 » Fri Feb 15, 2019 7:40 pm
Never made it out of the driveway last weekend. Too much going on.
Im still in need of the 250 pan.
Cheapest way to send something like that is to wrap it in cardboard, then plastic wrap and put it on a Grayhound.
65-coupe
Post #40 by 65-coupe » Fri Feb 15, 2019 8:13 pm
Okay so I need to get a shipping price.
65-coupe
Post #41 by 65-coupe » Fri Feb 15, 2019 8:24 pm
Pics
Georgia200
Post #42 by Georgia200 » Sat Feb 16, 2019 9:46 am
Sent you an email
Georgia200
Post #43 by Georgia200 » Sat Feb 16, 2019 9:48 am
Stopped by the machiine shop Friday and picked up my axles, They are going to start on the head and block this next week.
Hopefully I will be ordering engine parts.
Georgia200
Post #44 by Georgia200 » Thu Feb 21, 2019 8:09 pm
Still need the pan.
65-coupe
Post #45 by 65-coupe » Thu Feb 21, 2019 8:52 pm
Georgia200 wrote:Still need the pan.
Sorry been busy at work. Pm me your address
Georgia200
Post #46 by Georgia200 » Sat Feb 23, 2019 12:34 am
My machine guy keeps telling me next week.
I need to get some parts ordered, cant do anything until I find out how far down the pistons are sitting.
Users browsing this forum: No registered users and 24 guests
