<<< New Site Update >>>
Bronco Carb Options
ledslinger29
Bronco Carb Options
Post #1 by ledslinger29 » Sat Nov 23, 2019 9:30 pm
Hey Fellas,
I have a question for those of you with Bronco knowledge. I’ve grown tired of my 1100 on my 170. Have any of you put on a Weber 32/36? If so, did you have to modify the head at all, what did you do about the throttle cable, and did you have a problem with hood clearance? My carb has some issues that will cost me more to fix than it’s worth, and I’d like to get a little more go out of my little motor, but I don’t want to spend a pile of money on a dead end road. I’ve already got a DSII distributor from Bill.
68 Bronco Halfcab 170 wallered out .060 over, oversized valves, zero decked, 9:1 SCR, Autolite 1100 w/ Loadomatic/Pertronix, Schneider 248/56H cam
chad
Bronco Carb Options
Post #2 by chad » Sun Nov 24, 2019 11:03 am
I've enjoyed watchin ur build'n comments here over the yrs, not sure I have much to offer (beyond what I C here & experience in 37 yrs of bronk ownership). 1st off I would say - there is less need to ask bronk specific Qs. It's the same motor w/the same issues as a falcon, stang or any of the others - low hood (I do have some ideas gathered here 4 that), poor 'breathin', dyn0mite bottom end (ever have ur pan dwn to look @ those huge counter weights on the 170 crank) & so forth. The only reason I am in the process of a '69 250 swap is the cubes. I have not put on the RBS, am just now locating the motor in the frame & fabin the 250 'ring' to the 170 sump.
I choose the RBS as 1 of the 6 or 8 'low hood' wrk-a-rounds (W/advisement frm this site as a 215 cfm carb - possibly 'choke' ur 2.8L). U can look to the many threads here on the webber/holley progressive on any vehicle we address. There should B several on the current Index page (Ryan's most recent?) and those following, the Handbook & tech archive above. I seek tq & choices have tended toward largest i6 & largest 1V. I believe U want streetability and the webber seems a good choice (but tall & not a hi cfm for that optimal app - which is AFTER ALL - The primary Q 2 answ). ? Holley 4V 300 cfm ? I just DK~. Keep talkin, let us know how U do...
:thumbup:
bmbm40
Re: Bronco Carb Options
Post #3 by bmbm40 » Sun Nov 24, 2019 5:36 pm
I seem to remember that Weber carb needs an adapter so not sure about hood clearance problems. I have become interested in the Carter BBD carb it is a 2 barrel that can direct mount to the log head if you hog out the opening as some members have done and reported very good performance. They have not been made in years but a Chinese version is less than $100. I am considering it for my Bronco.
Soldmy66
Post #4 by Soldmy66 » Sun Nov 24, 2019 5:54 pm
bmbm40 wrote:I seem to remember that Weber carb needs an adapter so not sure about hood clearance problems. I have become interested in the Carter BBD carb it is a 2 barrel that can direct mount to the log head if you hog out the opening as some members have done and reported very good performance. They have not been made in years but a Chinese version is less than $100. I am considering it for my Bronco.
Like this one?
https://www.amazon.com/Twilight-Garage- ... 3298&psc=1
chad
Bronco Carb Options
Post #5 by chad » Mon Nov 25, 2019 5:21 pm
"...BBD..."
thank you Seth...
but seems pretty tall, if going 4 it I'd rather the 2100.
Ck the cfm 4 these as they R 4 bigger motors...
bmbm40
Post #6 by bmbm40 » Tue Nov 26, 2019 9:34 am
Yep that is it. Apparently they are available in three cfm ratings. I will find the post from the member that has done this conversion and provide the link. I like it because you avoid expensive machine costs and leave head on vehicle. And down the road you can still direct mount other carbs if your plans change or put original carb on.
ledslinger29
Post #7 by ledslinger29 » Mon Dec 02, 2019 4:14 pm
bmbm40 wrote:Yep that is it. Apparently they are available in three cfm ratings. I will find the post from the member that has done this conversion and provide the link. I like it because you avoid expensive machine costs and leave head on vehicle. And down the road you can still direct mount other carbs if your plans change or put original carb on.
That looks like a viable option, as I don’t want to have to modify the head if I can help it, and I can go back to the 1100 if I need to later. I’d like to see the post for sure, bmbm
bmbm40
Post #8 by bmbm40 » Mon Dec 02, 2019 4:59 pm
Hi
Can’t copy link and post here on iPad for some reason but will be home tomorrow or check post from
Econoline on Saturday April 6 2019. Thanks
ledslinger29
Post #9 by ledslinger29 » Mon Dec 02, 2019 9:27 pm
bmbm40 wrote:Hi
I found it. After reading that whole thread I’m not sure what to think!
chad
Post #10 by chad » Tue Dec 03, 2019 8:59 am
chad wrote:"...BBD..."
thank you Seth...
Isint he the one who brought it up? U lookin into the BBD? "Mr. Econoline"
here or Seth is very accommodating to inquiries - he sold me the 'early Mav mounts'
I'm usin to get the 250 in my bronk.
Econoline
Post #11 by Econoline » Tue Dec 03, 2019 12:11 pm
It was 63falcon4drwagon who did this mod and first brought up using a BBD. At the time I was looking at this carb b/c of its size. I'm still planning to use the 2CG version of the Holley Sniper version of the BBD. I would guess you'd want the 6 cylinder jeep version of this carb for you're 170 if you can make the linkage work. If you have a small log on you're 170 I'm not sure there is enough pad to do his mod.
https://fordsix.com/viewtopic.php?f=1&t=79809&p=617769#p617769
https://fordsix.com/viewtopic.php?f=1&t=79820&p=620837&hilit=BBD#p620837
He also mounted a Monojet:
https://fordsix.com/viewtopic.php?f=1&t=79837&p=618049#p618049
Also, there have been several guys on my van forum that have installed those "universal" 1 barrels on their 170's and been pleased with the results. They have an adjustable main jet. And you can install a weber with the Vintage Inlines adapter if you have enough hood clearance.
Good luck. And then there is the LOM distributor issue.
It ain't gonna fix itself
bmbm40
Post #12 by bmbm40 » Wed Dec 04, 2019 7:55 pm
Yep and this one
Good tip about the 170 head having enough pad to hog out.
chad
Bronco Carb Options
Post #13 by chad » Wed Dec 04, 2019 9:24 pm
I like that we R getting threads for specific carbs.
WIsh there were ways to sticky them. But...
I feel the same abt "specific heads" ('early', 'hex', 170, 200, late, etc). Rear ends ina 60s, 70s ford'n more, Seems like
it would B a bear to slice'n dice into 'a table of contents' type listing. My bet is
it would enhance our usability as a site. How bout this?: I;m willing to do so for
"All posts on 2V carb mounts on all i6 sm block falcon oem heads."
U guys got me goin ta nite !
Did I subscribe to deeply inta rbohm's signature line ?
DoctorC
Post #14 by DoctorC » Thu Dec 05, 2019 1:18 pm
I put a 32/36 on my Mustang 200 recently. Let me find the posts on the issues I had and post them here for you.
I went with a kit from VI, spacer included. I'm super happy with it all.
Incorrect vacuum hookup to Carb
viewtopic.php?f=1&t=80154
Mechanical throttle linkage woes
viewtopic.php?f=1&t=80387&p=623809#p623809
Fuel pump comment
viewtopic.php?f=1&t=80321&p=623281#p623281
Vac line setup post Weber
viewtopic.php?f=1&t=80368&p=623618#p623618
DS2 Dizzy thread:
viewtopic.php?f=1&t=80088
MSD Wiring problem
viewtopic.php?f=1&t=80187
1967 Cherry Red Mustang
Weber 32/36,
MSD 6AL+MSD Coil,
Duraspark 2 dizzy
chad
Bronco Carb Options
Post #15 by chad » Thu Dec 05, 2019 2:13 pm
(sorry, didn't mean here, in this guy's thread, if that's what U R doin Doc....)
DoctorC
Post #16 by DoctorC » Thu Dec 05, 2019 10:43 pm
Naw, just tryin to be helpful to the bloke. Links make life easier. =)
Weber 32/36,
MSD 6AL+MSD Coil,
Duraspark 2 dizzy
Users browsing this forum: No registered users and 27 guests
