Been awhile. I finally today gave it a spin. Put about a gallon of gas in tank, then dribbled some in carburator. Cranked and she was firing briefly, several times!! Think the gas is not through the line yet. Some gas seemed to leak through base of carb into where head bolt top sits. Tightened up base of carb and adapter. Then sparks were showing where I am pointing Right on Throttle linkage arm. Gas and sparks obviously do not mix. Done today. This could be a grounding issue? The block ground on line to alternator as shown in lower right, same picture. Maybe bad contact? Bubba, you still out there?
Adobejoe
Adobejoe
