62Ranchero200
Background: This is a solidly built 250 with a Clay Smith 274/274/108 cam, aluminum head, 500 CFM 2 BBL Holley, Ci headers, DUI.
The Ranchero is a weekend driver only, so it's common for me to go a week or two between driving it. It ran great until ...
Two weeks ago Saturday, I started it to go to my Falcon club meeting, then a cruise-in. It ran extremely roughly, wouldn't idle, and was extremely rich. The wideband was pegged out at 10.0, and the exhaust was eye-watering. I let it run for about 15 minutes, hoping it would warm up and run better and leaner, but it never did and I finally gave up and took my daily driver to the car club meeting. At the time, I thought that either the float or needle valve was stuck, flooding it with gas, or that the power valve had blown out and was leaking.
Tonight, I pulled the breather off and cranked it a good long time with a remote starter switch ... no gas was overflowing from the bowl vent and no drips from the venturi boosters - so apparently it's not a float or needle valve issue. I pulled the bowl off and replaced the power valve, but the issue remains. With unlimited time, after warming up it will idle ... but it still runs extremely roughly and is still extremely rich. I can see the squirt from the accelerator pump discharge nozzle when I work the throttle, so it definitely does have gas in the carburetor bowl. I don't hear any whistling sound, so I don't think there's any significant vacuum leak; and if there was it would probably be lean, not rich.
I put a timing light on it and the timing is spot on ... 20 degrees BTDC (yes I know that's quite a bit, but it's always been set there and the DUI is custom curved by WSA111). Oddly though, the timing light is only firing intermittently. Could this be a sign of an issue with the DUI? If the module or coil was going out, could it still run, but only fire intermittently? That could cause it to run rough and might cause the rich exhaust, since a non-firing plug would leave a charge of unburned gas in the cylinder. If I remember correctly, the timing light was steadily on the last time that I used it.
I thought about a bent pushrod or other valvetrain issue, but it would still fire correctly in that case, as evidenced by the timing light, right?
Any other ideas?
* Update: I checked the voltage at the BAT lead of the coil: 12.5 V. So apparently there's not an issue with my ignition switch or wiring.
Thanks,
Bob
Any other ideas?
Thanks,
Bob
