I'm getting ready to start the build up on my '68 200 with the following setup:
'68 block
OZ head/intake w Holley 2300 500 CFM 2V
264/274 – 214/224 - .450/.450 – 110* CAM
full roller rockers
dual roller timing
HiPo balancer
Pacemaker headers (dual out)
New stock dished pistons
I've had the block bored .020 over and decked to .010
I need to pick my target ratio so I'm looking for suggestions. I want to run stock fuel..don't mind using premium octane. With the Schjeldahl's compression calculator (http://falconperformance.sundog.net/compcalculator.asp) i put in my numbers using their stock info and my bore and deck mods and the thicker gasket number (.055) and I get:
8.8:1 @ 118hp (I'm sure the HP isn't right with the other MODS I'm doing, right?)
I left the volumetric efficiency at 80%, but wouldn't that be going up significantly with the OZ head, larger carb, and headers?
Also, what kind of RPM's should I use in that calculator? Stock is set to 4000.
Now, since I'm going with the OZ head, I'll need an accurate combustion chamber figure to start from to know how much to mill that head. I plan on CCing myself or course, but until it gets here, what chamber volume will I likely be working with? Based on that, how much should I look to mill off? From what the "Handbook" says, .060 = ~ 1.0 compression ratio points.
'68 block
full roller rockers
dual roller timing
HiPo balancer
