rmcphearson":2nk5lro9 said:I dunked the float in hot water. No bubbles. I think the float is good.
I checked the fuel pressure with a 100 psi gauge, it reads 6 psi. Don't know if it's accurate because of the scale.
I haven't been able to rig up something to bench pressure check the seat yet.
With the brass type floats shaking them you can hear if there is fuel inside them as well the fuel will seap out of the crack. They also feel much heavier than a good float does.
