bigblue91
this is my first carb rebuild and my question is
alright my carb kit is on the way for my carter yf. this yf i pulled off my 250 project is rusty near base and a little inside. how should i go by cleaning a carb, should i buy a gallon of carburetor cleaner (and let it soak) or should spray cans do and are wire brushes safe anywhere on a carb?
now questions for my 250 rebuild.
for my budget ive decided on the 264/274 -112 cam. porting the head myself. having head milled to improve compression. headers. adapter plate and 2 barrel (i dont think i could pull off direct 2 barrel machining). and replacing the internals of course.
my question is, with this setup will the 2 barrel with adapter be restricted and cause hesitation or should this engine run ok?
ive budgeted everything mentioned above and wanted your guys final opinion :mrgreen: on if this 250 will run ok with the above things done to it?
