Agreed, I put a 67 valve body in my 66 with a shift kit, and it made a huge difference being able to hold the car in gear longer and get those sharp shifts.
I downloaded a dynamic compression ratio calculator and played around a bit, and it looks like with some estimated numbers my current DCR is 7.35. That's lower than the 7.5-8.5 that I see as a good range, but not excessively low right?
Without decking the block or replacing pistons, the best I can do is 9.4 static / 8 dynamic if I stick with a composite gasket. That's milling the head to 48cc chambers (~.090" off total). If I mill the same off but use the steel shim, I'd jump to 10 / 8.5.
Any advice on those 2 options? 7.5-8.5 seems like a fairly large range... where should I aim for a reliable weekend car?
