I put in some new spark plugs today, and while I had them out I did a compression test.
1. 150
2. 145
3. 145
4. 146
5. 150
6. 145
I think this is good isn't it? This was done on a cold engine at 6,800' elevation.
When I put the plugs back in, I could tell I had a miss so I pulled spark plug wires 1 at a time till I found #6 was not firing. I put one of the old plugs back in and all was well. The new plug I had put in #6 had a light covering of oil on it. (I didn't use any oil when I did the compression test) Any idea where the oil would have come from? Bad valve guides? (wouldn't bad guides let the valves move around and effect compression?) Bad valve seals?
The old plugs all looked about the same, light gray ash deposits on the porcelain, black on the electrode. Are the ash deposits burned oil? I have a '82 large log head sitting on the shelf that has plugs like I'd expect to see, dark brown porcelain and black electrode.
1. 150
2. 145
3. 145
4. 146
5. 150
6. 145
