I have a dilemma. I have a motor with Block # C4OE-6015-A . It's in an Econoline. Probably originally came from a Fairlane. It has five freeze plugs in the right side, so I always assumed it was a seven-bearing 200. I seem to remember it having dished pistons, which would support that it's a 200 and not a 170. Now I'm not sure what it is.
Several years ago, I replaced the head and never measured the cylinders. I believe it has the larger distributor shaft. The thing had adjustable rocker arms, but from all I could tell it seemed to have hydraulic lifters, so I adjusted the valves as hydraulics and it runs great like that. Had its original cross hatching on the cylinder walls.
So here's my question: Is this a 200 with seven bearings? Or is it a 170? Or is it an oddball on of the early 200s with four bearings? Does it have solid or hydraulic lifters? Just what have I got?
I've read all the books; the Falcon Performance Handbook doesn't even mention the casting number. One guy on a forum says he opened one with this casting number and found four bearings even though it had five frost plugs. Hard to believe but I know there were some early 200's with four bearings.
Anyone have any thoughts on this? I don't want to pull the head or the oil pan; at least not right now.
Thanks for any help.
