I have a 1967 Bronco with a 170 six. After a maddening process I finally had my issue diagnosed and its my Fuel pump is not keeping up and hence starving my engine. With that in mind, I am having electric wipers installed so I do not need a vacuum pump which are MUCH more expensive. As I look at the mechanical pumps for non electric I am concerned that the cam is different. Does anyone know if this is an issue and where can I find a pump that is non vacuum? Here are a few links and I was hoping to buy locally to avoid shipping...
This version says its for 1969 and up...mine is a 1967 so will the cam be different and therefore this is not a solution?
https://shop.broncograveyard.com/19...tDOLRfhGj58SqdAbdmHyj3scXK7FyvQQaAigqEALw_wcB
This is the version I have now but I do not need the vacuum plus this is more than triple the cost.
https://www.oreillyauto.com/shop/b/...1/automotive-suv-1967-ford-bronco?q=fuel+pump
Does anyone know of if one of the auto parts chains has a mechanical option that will fit (cam) that has the non wiper vacuum port that I do not need? I am just looking for the least expensive solution to get back on the road...
thank you in advance for your thoughts...
