cameljockey
Hi everyone!
I am getting ready to purchase the Turbo!!!!!
I have included a detailed description of my build below and I wanted your input.
I would like to drive this car every day and take it to the strip every now and again.
+Turbo: Garrett GT3582R:
I need help choosing the Turbine sizing 0.63, 0.82, or 1.06 I am definitely using an external waste Gate.
I've already run this build by Will and I tend to agree with his suggestion because it is based in real world experience but I also asked a number of vendors about the appropriate turbine housing and they differ, and I would like as many opinions as possible
I won’t say what Will has suggested so as not to taint your thought processes.
I have done the Sizing math and the compressor is optimally sized for the air flow requirements of this build but the Turbine housing comes in three A/R ratios and I want to size it so that I don’t lag too much when I’m on the street. I don’t want to make more than 10 lbs of boost for the time being until Mike gets Cometic MLS gaskets at which time I will turn up the boost.
Bearing in mind that I want a fuel injected daily driver here
I have completed the following engine work:
Engine: Ford 250 cid L6
+Block: 0.030” over decked to 9.440”
+Pistons: Ross Racing Forged Al 8.7:1 Compression, Spiro-Locks, Full Floating Pins
+Crank: Turned 0.010 & 0.010 and Cryogenically Strengthened, Machined rear snout and rear main cap to accept 1 piece rear main seal from ’89 mustang 5.0.
+Rods: Cunningham 2 piece forged I-beam Bronze bushed for full floating Chevy pins
+Comp Cams: Dur @ 0.050
Int:224° Exh:218° LSA: 115°
Gross valve Lift:
Int:0.494 Exh:0.447
+CI Al Head & Cast Al IntakeThe head is being done by Mike's shop as of this writing)
-street / strip porting option 1.56” Exh Valve
-Viton seals
-64cc chamber
+Transmission: Ford Racing T-56 and associated Mcleod Industries Clutchery (TBD on the tranny here I like the idea of two overdrives and a shifter being farther back)
+Rear end: 3.70:1 Detroit Tru-trac worm gear posi, 31 spline axles,
+Tires: 245/45/ZR17
I really need some help with the Turbine housing size and any input is greatly appreciated and I eagerly await your arguments!
Keep Sixn'
Daniel Hanna
Gross valve Lift:
Int:0.494 Exh:0.447
-Viton seals
-64cc chamber
+Tires: 245/45/ZR17
Keep Sixn'
Daniel Hanna
