I wanted to know if the pressure bleed off on the front pedestal of the shaft assembly is necessary?
My problem: I don't get oiling to some of my rockers. I disassembled the shaft and cleaned all oiling holes. Oil pressure when priming is around 45-50 PSI. Was also cranking the engine, but still no oil.
What I want to try: Tap and plug the bleed off hole to have more pressure. I read some time ago that not all assemblies have the bleed off hole...
