Soldmy66":36272i3m said:when was the last time you changed your fuel filter? A clogged filter can cause intermittent bucking.
'N I like bub's comprehensive ign, tune up 1st.
U may need to go barrow tools (italics) at the local big box store,
then a move to fuel system:
"...Distributor rotates CC fireing order is 153624
Autolite BF-82 plugs gapped at .034.
Valve lash setting is .016 hot for both intake and exhaust valves.
Basic Points setting gaped at .025 for best performance your looking for a Dwell setting of 39 Degrees.
Base timing is set to 4 Degrees BTDC for a Standard ( Stick) trans and 10 Degrees BTDC for a Automatic trans.
Idle RPM is 600 RPM for a Standard Trans and 525 RPM with an Auto Trans in Drive, parking brake set, AC if you have that is off
Fuel pressure is 4.5 PSI
To get most accurate tune up I always use of a tach / dwel meter especially if your Distribitor is still using the stock type points, and also a timing light. This is the procedure I have found works the best and quickly for me. Customized settings for your Pertronix.
A good tune up follows this order of work.
1. Set the plug gap to .045 with a Pertronix ignition.
2. Set the points basic setting to .025 after its runing set the Dwell Angel to factory spec of 39 degrees. This step is not needed with the Pertronix system. Skip this setting with the Pertronix
3. Now you need to set the timing to 12 degrees base timing vacuum line disconnected and plugged. You can also try more base timing to as much as 16 degrees but it if there is any hint of pinging when you try it then back off until it stops. Reinstall the vaccum line to the Distribitor.
4. With the engine warmed up good, set the valve lash to .016 on intakes and exhaust valves.
5. With engine warmed up good, Set the Idle mixture to its Lean Best Idle. ie set to highest idel RPM then turn the mixture screw in 1/4 turn to lean it.
6. Set the curb idle speed to 575 to 600 RPM if stand. Trans. Set idle RPM's to 500 to 525 RPM with an Auto trans in drive parking brake set, wheels chocked with block of wood, or you can have your daughter set on and hold the brake.
7. Repeat 5. & 6. To see if it improves anymore. When properly tuned these engines (warmed up) will restart without even touching the gas pedel.
You might also test your coils output with the volt / ohm meter as well as the plug wires and cap for their resistance readings that they are within spec.
Additionally while doing the tune up settings to the carb mixture and idle the engine needs everthing hooked up just as it will be operated! This includes having the Air Cleaner with a clean air filter installed and the PCV hooked up if your engine has one. If you want to use a Vaccum gauge then hook that up to the Intake Log below the Carb you would be looking for about 17 inches of vacuum at idle RPM..."
Excellent that's some real good progress thats going in the right direction. Did you happen to reset the mixture screw to lean best idle and curb idle after installing the colder plugs? With each change these two should be reset.
